Peerless by Tymphany FSL-0615R02-08 Professional 6-1/2" Midrange Woofer 8 Ohm
Part #264-1402
Part #264-1402
Model: FSL-0615R02-08
The FSL-0615R02 8 ohm mid-woofer from Tymphany has smooth on and off axis response to over 3,000 Hz, making it an excellent woofer for a wide dispersion speaker system such as stage monitors or compact PA systems.
- Optimized multi-roll surround and spider for reduced distortion
- Extremely flat off axis response mates easily with wide dispersion tweeters
- High efficiency and excursion allow for high output without much effort
- Durable construction with a reinforced stamped steel frame ensures a long life
