  • Peerless DX25BG60-04 1" Silk Dome Tweeter 4 Ohm
CLEARANCE Peerless DX25BG60-04 1" Silk Dome Tweeter 4 Ohm
Peerless by Tymphany
Part #264-1478
Model: DX25BG60-04
With an incredibly low Fs of 415 Hz, high power handling, and smooth response, the Peerless DX25BG60-04 will provide fantastic performance for its price. Capable of handling extremely low crossover points, this tweeter will be right at home in 2-way reference designs.
  • Smooth on and off axis response with low Fs simplifies crossover design
  • Ferro fluid and a large ferrite magnet improves heat dissipation for high power handling
  • Thick aluminum faceplate provides a solid, non-resonant mounting structure
  • Bucking magnet concentrates magnetic field on the vice coil for more control
For 2-way designs with low crossover frequencies, the Peerless DX25BG60-04 1" soft dome tweeter will deliver exceptional performance. The DX25BG uses a large roll surround, silk dome, and Ferrofluid damping combined with a deep resonant chamber to achieve an extremely low Fs of 415 Hz allowing this tweeter to handle the lowest crossover frequencies. For a rigid, non-resonant mount, this tweeter uses a thick aluminum faceplate.
BrandPeerless by Tymphany
ModelDX25BG60-04
Part Number264-1478
UPC848864044989
Weight1.7
Cone / Dome Diameter1"
Cutout Diameter2.83
Tweeter TypeSoft Dome
Power Handling (RMS)80 Watts
Sensitivity93.99dB 2.83V/1m
Resonant Frequency (Fs)415.36Hz
DC Resistance (Re)3.47Ω
Voice Coil Inductance (Le)0.01mH
Mechanical Q (Qms)1.4
Electromagnetic Q (Qes)0.48
Total Q (Qts)0.35
Overall Outside Diameter4.1"
Depth2.4"
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
