  • Peerless 830500 12" XLS Subwoofer 4 Ohm
BUYOUT Peerless 830500 12" XLS Subwoofer 4 Ohm
Peerless
Part #299-2315
Peerless
Part #299-2315
Model: 830500
This new old stock, made in Denmark, Peerless 830500 12" XLS subwoofer is well known for its ability to deliver deep bass response with remarkably low distortion. Featuring a thoroughly vented cast frame, large roll rubber surround, Nomex fiber impregnated cone, and aluminum shorting rings, this classic driver is an excellent addition to any music or home theater system.
  • 12.5 mm of linear excursion for powerful output capabilities
  • Extremely durable cast aluminum frame with extensive venting
  • Flat spider and HD rubber half roll surround for linear excursion and low distortion
  • Massive stacked magnet for high efficiency and long excursion
  • New old stock original Peerless - Made in Denmark
Whether it's for an active home theatre subwoofer or for audiophile applications, Peerless 350500 12" XLS subwoofers have been fulfilling every demand for deep clean bass reproduction for well over a decade. Peerless of Denmark's design emphasis on the XLS 12" was to achieve tremendous deep bass, long time reliability, high power handling, and very low-distortion. Still a leader in high performance, low distortion driver technology, the 350500 features a light but rigid Nomex reinforced paper cone, thoroughly vented voice coil, large flat spider, large roll rubber surround, aluminum shorting ring, large aluminum pole cap, and extremely open cast aluminum frame.
For over 30 years, B-52 has manufactured Pro Audio gear in California using only high quality components. We recently acquired tons of product from them so they could free up space in their warehouse. This huge buyout of woofers, compression drivers, horns, crossover components, and cabinet hardware is listed here for a fraction of what you would normally pay. Many drivers in this factory buyout are New Old Stock (NOS) from famous brands and would be considered vintage. Like the B-52 bomber, this factory buyout travels the globe and includes drivers manufactured by famous brands around the world in places like the UK, USA, Denmark, and Brazil. This is a one-time buyout opportunity so quantities are limited.
BrandPeerless
Model830500
Part Number299-2315
UPC848864052144
Weight14.35
Nominal Diameter12"
Bolt Circle Diameter11.63
Power Handling (RMS)150 Watts
Power Handling (MAX)300 Watts
Frequency Response20 to 1,000Hz
Sensitivity90.9dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)21.5Hz
DC Resistance (Re)3.68Ω
Voice Coil Inductance (Le)1.71mH
Mechanical Q (Qms)3.34
Electromagnetic Q (Qes)0.26
Total Q (Qts)0.24
Compliance Equivalent Volume (Vas)3.3ft³
Mechanical Compliance of Suspension (Cms)0.3mm/N
BL Product (BL)18.66T·m
Diaphragm Mass Inc. Airload (Mms)182.1g
Maximum Linear Excursion (Xmax)12.5mm
Surface Area of Cone (Sd)467.6cm²
Cone MaterialPaper
Voice Coil FormerAluminum
Overall Outside Diameter12.12"
Baffle Cutout Diameter10.91"
Depth5.68"
Sealed Volume0.75ft³
Sealed F372Hz
Vented Volume1.5ft³
Vented F333Hz
MONSTER DEAL
OF THE WEEK
$23.98 EACH
SAVE 20%
Lepai LP‑2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
