PRV Audio WG 11-25 60 x 60 1" ABS Waveguide 1-3/8"-18 TPI
PRV Audio
Part #294-2842
PRV Audio
Part #294-2842
Model: WG 11-25
Use the PRV Audio WG 11-25 exponential horn to create small professional audio or DJ speakers with 1-3/8"-18 TPI screw-on compression drivers. 60° x 60° coverage is perfect for stage monitors where a tighter coverage pattern is needed.
- 60° x 60° dispersion pattern for personal stage monitors
- 1" throat diameter with 1-3/8"-18 TPI threads
- Lightweight ABS construction with exponential flare
- Acoustically loads compression drivers down to 1,200 Hz
