  • PRV Audio D270Ph-S 1" Phenolic Compression Driver 8 Ohm 1-3/8"-18 TPI
PRV Audio
Part #294-2959
PRV Audio
Part #294-2959
Model: D270PH-S
PRV Audio's D270Ph-S 1" compression driver is an updated and revised compact driver that is all about high output and low distortion vocal reproduction down to 500 Hz! This innovative driver is the perfect solution for use in high output PA and pro audio on wheels systems.
  • 2" phenolic diaphragm provides extreme clarity in the critical mid or vocal range
  • Updated and improved design based on our D250Ph-S
  • Ideal driver for mid-range and vocal sound reinforcement
  • Compact driver size is perfect for conditions where space is a concern
Your Price: $31.91
MSRP: $43.64
Save $11.73 (27%)
Based on the design of PRV Audio's D250Ph-S, the D270Ph-S 1" compact compression driver was built to fulfill the demand in the market. The small diameter of the driver provides front mounting without detaching the driver from the horn, making it effortless to install into tight spaces. The high-temperature copper wire used for the voice coil is wound on a Kapton former to withstand high operating temperatures. The old replacement diaphragm RPD250Ph still fits the D270Ph-S driver. The nearly-indestructible phenolic diaphragm can play down to 500 Hz and resists the elements, making it ideal for outdoor use.
Designed to reproduce the all-important vocal range with authority, the D270Ph-S is an excellent pick for high power public address (PA) systems, small venues, and gymnasiums. Car audio SPL enthusiasts regularly utilize this driver for vocal reinforcement on high output 3-way systems.
BrandPRV Audio
ModelD270PH-S
Part Number294-2959
UPC602938022484
Weight2.8
Diaphragm MaterialPhenolic
Exit Diameter1"
Mounting Type1-3/8"-18 TPI
Power Handling (RMS)75 Watts
