  • PRV Audio 8MR400 8" Midrange Woofer
NEW PRV Audio 8MR400 8" Midrange Woofer
Read 1 Review or
PRV Audio
Part #294-3532
PRV Audio
Part #294-3532
Model: 8MR400
Read 1 Review or
Experience superior midrange performance with the PRV Audio 8MR400, an 8-inch midrange woofer engineered for exceptional sound clarity and power. Designed for both car audio enthusiasts and professional sound systems, this woofer delivers deep, punchy bass and accurate midrange frequencies to elevate your listening experience.
  • 400W peak power handling for powerful audio performance
  • 8-inch cone for rich midbass and clear midrange frequencies
  • 8-ohm impedance for versatile system compatibility
  • Wide frequency response from 80Hz to 6kHz for detailed sound reproduction
  • High sensitivity of 96 dB for efficient and loud output
NEW $34.91
MSRP: $43.64
Save $8.73 (20%)
Order in the next 2 hr 3 min to ship today. Details
The PRV Audio 8MR400 midrange woofer is crafted to bring out the best in your audio system. With a peak power handling of 400 watts, this woofer provides robust and dynamic sound, ensuring your music's midrange frequencies are delivered with impact and precision. Whether you're listening to bass-heavy tracks or detailed vocals, the 8MR400 ensures every note is heard with clarity.
Featuring an 8-inch cone, this woofer excels in producing rich and punchy midbass tones, while also handling midrange frequencies with accuracy. The 8-ohm impedance makes it compatible with a wide range of amplifiers and audio systems, providing flexibility in your setup. Its wide frequency response range of 80Hz to 6kHz captures the essential details of your music, from the deep lows to the nuanced mids.
With a high sensitivity rating of 96 dB, the 8MR400 efficiently converts power into sound, delivering loud and clear audio output without demanding excessive power from your amplifier. This efficiency ensures that your audio system operates at its best, providing a powerful and immersive listening experience.
Durably constructed, the PRV Audio 8MR400 is built to withstand the rigors of continuous use, making it a reliable choice for both car audio installations and professional sound systems. Whether you're upgrading your vehicle's audio system or enhancing a professional setup, this midrange woofer offers the perfect combination of power, clarity, and reliability.
Upgrade your sound system with the PRV Audio 8MR400 8" Midrange Woofer and experience the difference in audio performance and quality. Enjoy rich midbass and clear midrange frequencies that bring your music to life with exceptional clarity and depth.
BrandPRV Audio
Model8MR400
Part Number294-3532
UPC810075525267
Weight26
Nominal Diameter8"
Power Handling (RMS)400 Watts
Power Handling (MAX)800 Watts
Frequency Response90 to 7,500Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)78.2Hz
DC Resistance (Re)5.4Ω
Voice Coil Inductance (Le)0.42mH
Mechanical Q (Qms)8.52
Electromagnetic Q (Qes)0.56
Total Q (Qts)0.52
Compliance Equivalent Volume (Vas)0.714ft³
Mechanical Compliance of Suspension (Cms)0.295mm/N
BL Product (BL)8.15T·m
Diaphragm Mass Inc. Airload (Mms)14.05g
Surface Area of Cone (Sd)222cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Overall Outside Diameter8.27"
Baffle Cutout Diameter6.97"
Depth3.27"
Sealed Volume0.404ft³
Sealed F3126.7Hz
Vented Volume1.218ft³
Vented F360.88Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
