  • PRV Audio 2DF2k 2-Way Passive Speaker Crossover 2 kHz
CLEARANCE PRV Audio 2DF2k 2-Way Passive Speaker Crossover 2 kHz
PRV Audio
Part #294-2860
PRV Audio
Part #294-2860
Model: 2DF2k
Get your two-way professional audio speaker cabinet up and running like new with the PRV Audio 2DF2k crossover. A speakON-compatible input and pass-through output makes amplifier connection simple, quick, and secure.
  • Perfect replacement crossover for two-way speaker cabinets
  • speakON-compatible input/output connectors
  • Parallel output connections for daisy-chaining speakers
The PRV Audio 2DF2k crossover was originally designed to be used as a replacement crossover in their PRV-115 speaker cabinets. A 2 kHz crossover point and 12 dB/octave filter slope allows it to be used in nearly any two-way pro audio speaker cabinet.
For safe, secure, and quick amplifier connection, PRV Audio built the 2DF2k crossover with a 4-pole speakON-compatible input jack and output pass-through (for daisy-chaining multiple speakers together). High quality components are used throughout for longevity and great sound.
Note: Each connector is wired 1+ to 2+ and 1- to 2-. Please consult your amplifier manual to see if this affects amplifier operation prior to connecting 4-pole speakON-compatible speaker cables. 2-pole speakON-compatible speaker cables are not affected.
Specifications: • Power handling: 450W RMS • Crossover point: 2,000 Hz (when connected to 8 ohm drivers), 12 dB/octave • Input/output connections: 4-pole speakON-compatible (see note above) • Overall dimensions: 5.2" W x 7.1" H x 3.75" D, Cutout: 3.9" W x 5.9" H.
BrandPRV Audio
Model2DF2k
Part Number294-2860
Weight1.55
ConfigurationIncludes Connector Dish
Crossover Type2-Way
    MONSTER DEAL
    OF THE WEEK
    $24.98 EACH
    SAVE $5
    Lepai LP-2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
