  • PRV Audio 12MR2000-NDY 12" Neodymium Professional Midrange 8 Ohm
PRV Audio
Part #294-2748
PRV Audio
Part #294-2748
Model: 12MR2000-NDY
PRV Audio designed the 12MR2000-NDY for maximum midbass punch and exceptional midrange clarity to meet the demands of today’s high SPL systems. Featuring a new motor, voice coil, and suspension, the 12MR2000-NDY will deliver reliable performance in any high SPL installation.
  • Neodymium motor reduces weight without sacrificing anything
  • Inside-outside wound voice coil distributes heat evenly for lower compression
  • Extensive venting keeps voice coil cool at high power handling over long periods
  • Solid cast frame provides rigid support for the large neodymium magnet
Your Price: $219.91
MSRP: $274.89
Save $54.98 (20%)
11In Stock
PRV Audio's 12MR2000-NDY will change the game on vocal reproduction!
This driver features a cutting edge 4” CCAW inside/outside wound voice coil resulting in very high efficiency while providing smooth and accurate response through the vocal range. To help cool the voice coil under high power the motor assembly uses extensive venting through the pole piece, voice coil gap, and under the spider. By using a naturally damped paper cone and non-resonant accordion surround, the12MR2000-NDY will produce the same smooth and accurate midrange response that PRV has become known for. Capable of handling up to 1,000 watts RMS with 98 dB efficiency the 12MR2000-NDY will be able to keep up with even the highest output home, professional, and automotive systems.
BrandPRV Audio
Model12MR2000-NDY
Part Number294-2748
UPC602938021449
Weight15.8
Nominal Diameter12"
Frequency Response55 to 5,500Hz
Sensitivity98dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)54.48Hz
DC Resistance (Re)6.6Ω
Voice Coil Inductance (Le)0.69mH
Mechanical Q (Qms)17.61
Electromagnetic Q (Qes)0.35
Total Q (Qts)0.34
Compliance Equivalent Volume (Vas)1.7ft³
Mechanical Compliance of Suspension (Cms)0.11mm/N
BL Product (BL)22.77T·m
Diaphragm Mass Inc. Airload (Mms)81.11g
Maximum Linear Excursion (Xmax)6.15mm
Surface Area of Cone (Sd)573cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter12.32"
Baffle Cutout Diameter11.12"
Depth5.54"
Sealed Volume0.75ft³
Sealed F3130.2Hz
Vented Volume1.75ft³
Vented F354.6Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
