  • PRV Audio 10MR1000X 10" Professional Midrange Driver 8 Ohm
CLEARANCE PRV Audio 10MR1000X 10" Professional Midrange Driver 8 Ohm
PRV Audio
Part #294-2985
PRV Audio
Part #294-2985
Model: 10MR1000X
Extreme mid range performance is what PRV Audio's 10MR1000X is designed for. Not only can it handle an impressive 500 watts RMS, it does so while remaining linear from 300 to 3,000 Hz.
  • Coated woven surround offers smooth, precise geometry during hard play
  • Inside-outside voice coil
  • Impressive 100 dB sensitivity
  • Extremely linear from 300 to 3,000 Hz
The PRV Audio 10MR1000X is the evolution of our line, after intense 2 years of development we have created the mid range loudspeaker that offers outstanding durability, high power handling at sensitivity rating of 100 dB 1W/1M which makes it capable of generating a lot of output! This specially designed loudspeaker is assembled with top of the line components for long lasting play, even during intense use.
A coated woven surround offers smooth, precise geometry during hard play, the 3" inside/outside copper voice coil is wrapped on a glass fiber former for heat resistance and high efficiency, while providing smooth and accurate response. The light weight cone provides excellent linear response up to 3,000 Hz, making the 10MR1000X a great solution for high quality two or three-way systems.
Extreme car audio enthusiasts will find PRV Audio's 10MR1000X to be the perfect 10" mid range door speaker, capable of handling up to 500 watts RMS power (with a suggested 140 Hz, 18 dB/octave high pass filter in place)! The large magnet assembly is attached to a sturdy, reinforced cast-aluminum frame.
BrandPRV Audio
Model10MR1000X
Part Number294-2985
UPC602938021791
Weight17.1
Nominal Diameter10"
Power Handling (RMS)500 Watts
Frequency Response75 to 6,000Hz
Sensitivity100dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)72.02Hz
DC Resistance (Re)5.2Ω
Voice Coil Inductance (Le)0.43mH
Mechanical Q (Qms)11.22
Electromagnetic Q (Qes)0.23
Total Q (Qts)0.22
Compliance Equivalent Volume (Vas)1.01ft³
Mechanical Compliance of Suspension (Cms)0.134mm/N
BL Product (BL)19.42T·m
Diaphragm Mass Inc. Airload (Mms)36.26g
Surface Area of Cone (Sd)391cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil FormerFiberglass
Overall Outside Diameter10.23"
Baffle Cutout Diameter9.01"
Depth4.27"
Vented Volume1ft³
Vented F372.2Hz
MONSTER DEAL
OF THE WEEK
$45.98 EACH
SAVE $12
Dayton Audio KABD-250 2 x 50W All-in-one Amplifier Board with DSP and Bluetooth 5.0 aptX HD
