  • PKCELL Flat Top 18650 3.7V 3350mAh Rechargeable Li-Ion Battery
PKCELL
Part #142-211
PKCELL
Part #142-211
Always have an extra charged backup battery waiting, or start a new project with this 18650 Li-Ion battery for your flashlight or other electronic devices.
  • Long lasting standby charge
  • Standard size 18650 Li-Ion battery
  • 3350mAh for current hungry devices
Your Price: $7.98
MSRP: $12.99
Save $5.01 (39%)
Quantity:Qty: 1-3 $7.98/ea
Quantity:Qty: 4-11 $7.49/ea
Quantity:Qty: 12-79 $7.28/ea
Quantity:Qty: 80+$6.93/ea
Order in the next 1 hr 51 min to ship today. Details
16In Stock
A growing number of electronic devices use 18650 Li-Ion batteries. Flashlights are using the 18650 battery to power the current hungry LED bulbs, and to provide longer standby time when not in use. Previous rechargeable battery flashlights had to be left on the charger almost all the time so that it would be ready to use in a moment's notice. This 18650 Li-Ion battery can be left off the charger for months and still have over 90% of its charge. This enables you to charge an extra battery and have it ready to use in your flashlight in case you are going to be away from electricity for a long period of time or you forget to charge your original battery.
The 18650 3350mAh Li-Ion battery has the ability to power Dayton Audio Bluetooth amp boards when you combine them with a special Dayton Audio charging board. The KAB-BE holds three 18650 batteries and delivers longer playing time and standby time when using it with your KAB Bluetooth amp boards.
Note: Do not throw the battery into the fire. Do not solder directly to the battery. Do not store the battery in heavy static electricity areas. Do not mix the battery with different brands, chemicals, or amperage ratings. Wash your skin or clothing immediately if the battery leaks onto them. If any chemicals get into your eyes do not rub them, but wash your eyes with clean water and call a doctor. Keep out of reach of young children to avoid swallowing.
Specifications: • Voltage: 3.7 DC • Current rating: 3350mAh • Charging environment temperature range: 32° to 113° F • In use temperature range: -4° to 140° F • Size: 0.73" Dia. x 2.56" H.
BrandPKCELL
Part Number142-211
UPC848864065083
Weight0.1
Size18650
TechnologyLi-Ion
Voltage3.7V
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
