Orian 3-Way High-Output Bookshelf Speaker Kit Pair With Knock Down Enclosures
The Orian High Output Bookshelf Speaker Kit’s unique design delivers SPL levels you would normally only expect from larger tower speakers, while creating a spacious soundstage that will put you in the center of the performance. Utilizing an open back midrange enclosure, the Orian takes advantage of reflected sound to produce room filling output.
Features:
- Unique open back midrange eliminates “boxy” coloration and uses reflected sound for wider soundstage
- Coaxial midrange/tweeter drivers minimize interaction for more consistent on and off -axis response
- 8" high excursion woofers produce powerful low frequency response even when driven to high SPL
- Included printed circuit board makes crossover assembly easier than ever
- ±3 dB from 35 to 20,000 Hz for natural full-range response without the need for a subwoofer
- Precision CNC cut MDF cabinet panels make the enclosures easy to assemble with minimal tools
- Includes everything required for open back or damped rear chamber configurations
Customer Projects:
Read Audiohiloc's review of the Parts Express Orian Kit here:
https://www.audioholics.com/bookshelf-speaker-reviews/parts-express-orian-3-way
Kit Components:
Part # | QTY. | Description |
999-386 | 2 | Dayton Audio CX150-8 5-1/4” Coaxial Driver with 1" Silk Dome Tweeter |
295-200 | 2 | Dayton Audio DCS205-4 8” Classic Subwoofer 4 Ohm |
027-412 | 2 | Dayton Audio DMPC-1.5 1.5uF 250V Polypropylene Capacitor |
027-430 | 2 | Dayton Audio DMPC-12 12uF 250V Polypropylene Capacitor |
027-434 | 2 | Dayton Audio DMPC-18 18uF 250V Polypropylene Capacitor |
027-439 | 2 | Dayton Audio DMPC-27 27uF 250V Polypropylene Capacitor |
027-458 | 2 | Dayton Audio DFFC-0.47 0.47uF 400V By-Pass Capacitor |
027-416 | 2 | Dayton Audio DMPC-2.7 2.7uF 250V Polypropylene Capacitor |
027-362 | 2 | 125uF 100V Electrolytic Non-Polarized Crossover Capacitor |
257-036 | 2 | Dayton Audio 0.50mH 20 AWG Air Core Inductor Crossover Coil |
257-658 | 4 | Dayton Audio IC183 3.0mH 18 AWG Laminated Iron Core Inductor |
257-052 | 2 | Dayton Audio 1.5mH 20 AWG Air Core Inductor Crossover Coil |
007-30 | 6 | DPR20-30.0 30 Ohm 20 Watt Precision Bifilar Resistor |
007-40 | 2 | DPR20-40.0 40 Ohm 20 Watt Precision Bifilar Resistor |
- | 2 | Orian (CX 3-way) Crossover Printed Circuit Board Precision CNC cut MDF Knock-down cabinet panels Wire, hardware and other components |
Note:Crossover components may be substituted with parts of equal or higher quality depending on available inventory.
- Power Handling: 150 watts RMS/300 watts max
- Frequency response: ±3 dB from 37-20,000 Hz (±6 dB from 30- 20,000 Hz)
- Impedance: 4 Ohm
- Sensitivity: 83 dB 1W/1m
- Dimensions: 21” H x 11” W x 13” D
