  • Onkyo TX-NR646 7.2 Network Home Theater Receiver 170 Watts per Channel with Powered 2nd Zone
CLEARANCE Onkyo TX-NR646 7.2 Network Home Theater Receiver 170 Watts per Channel with Powered 2nd Zone
Onkyo
Part #252-514
Onkyo
Part #252-514
Model: TX-NR646
Enjoy cutting edge home theater technology with the Onkyo TX-NR646. This network A/V receiver is up to date on the latest HDMI specifications as well as theater sound protocols like DTS:X and Dolby Atmos which allow you to experience true depth from your movies. Add in Bluetooth and Wi-Fi connectivity, app controlled features, a powered second zone, high-resolution DAC, and crystal clear amplifier sound stage and the TX-NR646 is a top of the line 7.2 channel receiver that is sure to please.
  • DTS:X and Dolby Atmos compatibility adds height speakers for a total surround experience
  • HDCP 2.2 certified to work with 4K Ultra HD content - 8 HDMI inputs
  • Bluetooth and Wi-Fi enabled for streaming music from Onkyo app and services like Pandora and Spotify
  • Phono input and preamp brings the most out of your albums
  • Hi-Res Asahi Kasei DAC streams crystal clear digital music up to 384 kHz/32-bit rates
  • Powered and line level zone 2 provides music to a second room
  • AccuEQ room calibration mic included for automatic speaker setup
DTS:X Compatible
DTS:X is a next-generation object-based surround sound technology that includes height to deliver a fully-immersive listening experience. It provides listeners the ultimate in flexibility, immersion, and interactivity. Unlike channel-based audio, you will be able to personalize your audio experience. For example, you can turn up just the dialog within a mix. DTS:X allows you to customize to your room layout as well as control dialog and dynamic range.
Supports Dolby Atmos Up to 5.1.2 Channels
With Dolby Atmos, sound comes alive from all directions, including overhead. The format combines a channel-based audio bed with object-oriented sound to place and move specific effects around the room, creating a breathtakingly realistic and captivating sonic atmosphere. Sound designers and artists are free to mix in a 3D space, steering effects through surround channels and adding a seamless overhead dimension with discrete height channels. Additionally, a new Dolby surround up-mixer allows for your current channel-based content (that has not been mixed for Dolby Atmos) to be expanded to fill the flexible speaker layouts of a Dolby Atmos system.
Ready for 4K UltraHD
The latest HDMI specification and HDCP 2.2 compatibility support the latest formats and technologies planned for Hollywood content. This latest HDMI spec offers a significant increase in bandwidth (up to 18Gbps) to support new features such as 4K@50/60 (2160p), which is 4 times the clarity of 1080p/60 video resolution, and 4:4:4 color space. This Onkyo AVR enables transmission of High Dynamic Range (HDR) formats, and provides enhanced picture quality by simultaneously enabling greater detail for both the dark and bright parts of an image.
Bluetooth / Wi-Fi with Pandora, Spotify, and AirPlay
The TX-NR646 has AirPlay, Wi-Fi, and Bluetooth technologies built in. The free Onkyo Remote app puts a range of streaming options at your fingertips, from universal Hi-Res audio via network-attached devices to internet streaming services to music on your smartphone and tablet. Or pair up and enjoy whatever is playing on your Bluetooth-compatible device for huge cinematic sound. This receiver comes loaded with Spotify, Pandora, SiriusXM Internet Radio, Slacker, and TuneIn. You can select a station and search for music available on these services via the Onkyo Remote app on your phone. You'll never be short of your favorite music to enjoy.
Hi-Current Amp Design for Authentic Sound Reproduction
From the quietest dialog passages to booming action scenes, Onkyo's exclusive amplification technology dramatically enhances the audio dynamics of your movies, music, and video games.This Wide Range Amplifier Technology (WRAT) is at the core of Onkyo's signature sound. The innovative amplifier design is comprised of three key elements:
• A low negative feedback design for punchy, true-to-life sound, and cleaner audio across the frequency ranges
• Closed ground loop circuits to reduce individual circuit noise and keep the ground potential free of distortion
• A high instantaneous current to handle big dynamic gains
384 kHz/32-bit Hi-Grade DAC
No matter what you're listening to, it will sound powerfully full, clean, and clear. A premium-quality AK4458 DAC from Asahi Kasei implements unique low-distortion filtering technologies for clear sound, and unlocks the full potential of any audio format, including compressed, lossless, and Hi-Res audio (MP3, WMA, WMA Lossless, FLAC, WAV, OggVorbis, AAC, Apple Lossless, DSD 5.6 MHz, LPCM, and Dolby TrueHD).
Classic Analog & Hi-Res Digital
This receiver is engineered for hi-res analog and digital audio. You can spin your classic vinyl and hear it in all its analog glory and stream your networked Hi-Res digital files. Both analog and digital audio sound its warmest and clearest. The TX-NR646 supports hi-res audio playback, gapless playback, and the ability to play DSD, Double DSD, FLAC , and ALAC along with other Hi-Res formats.
Powered Zone 2 and Zone 2 Line-Outs
The TX-NR646 features a powered zone 2 and zone 2 line outputs. This lets you assign two channels to power audio in a room equipped with speakers. An existing hi-fi system in a third room can also be connected via the line-out, enabling the use of the A/V receiver as a pre-amp and audio server.
Specifications: • Power output: 100 watts RMS @ 8 ohms (2 ch driven), 170 watts peak @ 6 ohms (1 ch driven) • Dynamic power: 240 watts @ 3 ohms, 210 watts @ 4 ohms, 120 watts @ 8 ohms • Total harmonic distortion: 0.08% • input sensitivity: 200 mV • Frequency response: 10-100,000 Hz • Signal to noise ratio: 100 dB • Speaker impedance: 6-16 ohms • Supported home theater audio: DTS:X, Dolby Atmos, TrueHD, DD Plus, PLIIz, DTS-HD • HDMI: 8 in/ 2 out • HDMI 2.0 4K, 3D, audio return • Inputs: 7 stereo RCA, phono, 2 digital optical, digital coaxial, 3 composite video, 2 component video, USB, and Ethernet port • Outputs: 2 subwoofer pre-outs, stereo RCA zone 2 • D/A converter: 384 kHz/32-bit • Bluetooth included • Wi-Fi certified • Dimensions: 17-1/8" W x 6-13/16" H x 12-15/16" D.
BrandOnkyo
ModelTX-NR646
Part Number252-514
UPC751398012228
Weight26.2
Power Output Per Channel170Watts
Receiver Type7.2 Channel Surround
    MONSTER DEAL
    OF THE WEEK
    $19.98 EACH
    SAVE 20%
    Shadow Mounts DTS65 Universal Sturdy Desktop Tabletop Entertainment Center TV Monitor Stand Up to 65"
