  • Neutrik NL8FC speakON Connector 8 Pole Cable Mount
NeutrikPart # 092-051
Model: NL8FC
Patent protected, reliable, cost effective, and extremely durable, Neutrik's speakON series of professional speaker and amplifier connectors offers the "quick lock" locking system and recently redesigned inserts for the cable ends.
  • Professional speaker and amplifier connectors offer the "quick lock" locking system
  • Contacts are touch proof and designed to prevent damage from arcing if disconnected under load
  • Fail-safe conditions for both the equipment and the operator
Your Price: $15.01
MSRP: $19.99
Save $4.98 (25%)
Quantity:Qty: 1-99 $15.01/ea
Quantity:Qty: 100-249 $14.21/ea
Quantity:Qty: 250+ $13.67/ea
94 In Stock
We'll send you an email when Neutrik NL8FC speakON Connector 8 Pole Cable Mount is back in stock or available for preorder.
Neutrik's speakON series of professional speaker and amplifier connectors are recognized as the industry standard. Patent protected, reliable, cost effective, and extremely durable the speakON system offers the "quick lock" locking system and recently redesigned inserts for the cable ends. The inserts feature solderless connections using the new pozidrive and slot combination screw terminals with a captive pressure plate. No special tools are required making these connectors 100% field repairable.
The contacts in this series are touch proof and designed to prevent damage from arcing if disconnected under load. Ensuring fail-safe conditions for both the equipment and the operator. speakON meets the prevailing safety standards of IEC65, IEC348, CE, CSA and are UL rated (file #E135070).
Specifications: • Connector type: Cable end connector, 8-pole • Accepts 8-20 mm OD cable • Mfg. #NL8FC.
BrandNeutrik
ModelNL8FC
Part Number092-051
Weight0.16
Circuit8-Pole
GenderFemale
Mounting TypeCable Mount
