  • Neutrik NL2MP speakON Connector 2 Pole Panel Mount
Neutrik
Part #092-059
Neutrik
Part #092-059
Patent protected, reliable, cost effective, and extremely durable, Neutrik's speakON series of professional speaker and amplifier connectors offers the "quick lock" locking system and recently redesigned inserts for the cable ends.
  • Industry standard "quick-lock" speaker connection
  • 2-pole panel/chassis connector
  • Familiar "D" Series form factor
  • Black finish
Your Price: $2.66
MSRP: $3.99
Save $1.33 (33%)
Quantity:Qty: 1-99 $2.66/ea
Quantity:Qty: 100-249 $2.48/ea
Quantity:Qty: 250+$2.38/ea
Estimated back in stock 6/6/2025
Alert Me When Available
Neutrik's speakON series of professional speaker and amplifier connectors are recognized as the industry standard. Patent protected, reliable, cost effective, and extremely durable the speakON system offers the "quick lock" locking system. speakON panel receptacles with solder terminations also allow you to use quick disconnect type terminals (0.187" x 0.020") for ease and reliability of assembly.
The contacts in this series are touch proof and designed to prevent damage from arcing if disconnected under load. Ensuring fail-safe conditions for both the equipment and the operator. speakON meets the prevailing safety standards of IEC65, IEC348, CE, CSA and are UL rated (file #E135070). Connector type: Chassis connector/panel receptacle, 2-pole, "D" series style with air-tight seal.
Note: Does not intermate with the 4-pole (NL4) cable connectors.
BrandNeutrik
ModelNL2MPXX
Part Number092-059
UPC703272072545
Circuit2-Pole
GenderMale
