  • Neutrik NBB75DFIX BNC "D" Feed-Through Isolated Chassis Connector Antraloy 75 Ohm
NEW Neutrik NBB75DFIX BNC "D" Feed-Through Isolated Chassis Connector Antraloy 75 Ohm
Neutrik
Part #092-373
Neutrik
Part #092-373
Model: NBB75DFIX
The Neutrik NBB75DFIX is a high-quality BNC feed-through connector, meticulously engineered to provide a reliable connection for both digital and analog signals in professional settings. This isolated chassis connector is designed to fit perfectly into standard "D" shaped panel cutouts, making it an ideal choice for broadcast studios, live production trucks, and audio-visual installations.
  • High-Frequency Signal Integrity: Optimized for both digital and analog signals, ensuring clear, uninterrupted transmission.
  • Isolated Chassis Design: Minimizes potential grounding issues and electromagnetic interference, enhancing signal clarity.
  • Universal "D" Shaped Panel Mount: Easy to install in standard panels, offering a secure and stable connection.
  • Robust Construction: Built from high-quality materials, ensuring durability and reliability for professional use.
  • Versatile Application: Ideal for broadcast, video, audio, and multimedia installations, supporting a wide range of professional environments.
NEW $10.83
MSRP: $12.82
Save $1.99 (16%)
Quantity:Qty: 1-99 $10.83/ea
Quantity:Qty: 100-249 $10.25/ea
Quantity:Qty: 250+$9.86/ea
69In Stock
The Neutrik NBB75DFIX is a high-quality BNC feed-through connector, meticulously engineered to provide a reliable connection for both digital and analog signals in professional settings. This isolated chassis connector is designed to fit perfectly into standard "D" shaped panel cutouts, making it an ideal choice for broadcast studios, live production trucks, and audio-visual installations. Its isolated design ensures minimal interference and maximum signal integrity, making it a cornerstone for any setup that demands the highest quality in signal transmission.
Engineered for impeccable transmission of high-frequency digital and analog signals, the NBB75DFIX ensures that your content is delivered with the clarity and precision required in professional settings.
The isolated chassis design effectively reduces grounding issues and electromagnetic interference, providing a pristine signal path that is critical for high-quality broadcasts and recordings.
Designed to fit perfectly into standard "D" shaped panel cutouts, this connector offers a straightforward installation process, ensuring a flush and secure mount for a sleek and professional setup.
Constructed with durability in mind, the NBB75DFIX stands up to the demands of rigorous professional use, ensuring a long-lasting and reliable connection for your critical signal paths.
Whether in broadcast studios, live production environments, or sophisticated AV installations, the NBB75DFIX offers the versatility and performance to meet the needs of any professional application.
BrandNeutrik
ModelNBB75DFIX
Part Number092-373
UPC848864076232
