  • Neutrik NAC3MPA-1 powerCON Chassis Connector Power In Blue
CLEARANCE Neutrik NAC3MPA-1 powerCON Chassis Connector Power In Blue
Neutrik
Part #092-284
Neutrik
Part #092-284
Model: NAC3MPA-1
PowerCon® is a lockable 3-pole equipment (AC) connector with contacts for line, neutral and premating safety grounds. • Connector: PowerCon® chassis connector • Type: Power In • Color: Blue (A) • Mfg. #NAC3MPA
  • 3-conductor quick disconnect terminations for easy and reliable assembly
  • Field serviceable, robust, and unbreakable
  • Fail-safe, long life electrical termination integrity
  • Developed for frequently connected/disconnected systems with operator and equipment safety in mind
PowerCon® is a lockable 3-pole equipment (AC) connector with contacts for line, neutral and premating safety grounds. Color coded for easy identification, PowerCon® offers power-in (blue) and power-out (gray) versions with different keying to avoid the possibility of short circuiting. The contacts are designed to prevent damage from arcing when disconnected while under load. PowerCon® meets or exceeds the demands of applications in the fields of A/V usages, test and measurement equipment, computers or industrial designs. UL recognized, SEV and VDE approved. Rated at 20A/250 VAC.
• Connector: PowerCon® chassis connector • Type: Power In • Color: Blue (A) • Termination: For use with 0.187" x 0.020" quick-connect terminals • Mfr. #NAC3MPA
Note: PowerCon® is not designed to be a "mains" connector or for speaker/amplifier applications. For speaker applications please see the Speakon® series.
BrandNeutrik
ModelNAC3MPA-1
Part Number092-284
Weight0.1
ConfigurationNeutrik powerCON
Current Rating20A
Power Connector TypeChassis / Panel Mount
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE 20%
Shadow Mounts DTS65 Universal Sturdy Desktop Tabletop Entertainment Center TV Monitor Stand Up to 65"
