CLEARANCE NTE R10-11D10-24 10A 24 VDC DPDT Ice Cube Relay
We'll send you an email when NTE R10-11D10-24 10A 24 VDC DPDT Ice Cube Relay is back in stock or available for preorder.
10 Amp general purpose ice cube relay with clear see through cover. DPDT, 24 VDC, 0.187" (4.75 mm) 3-way terminals suitable for plug-in, solder, and quick connect.
Electrical Specifications:
Contact • Contact material: 3/16" Silver cadmium oxide.
Coil • Nominal voltage: 24VDC • Contact arr.: DPDT • Coil res.: 470 ohms • Nominal power: 1.2W • Max. contact current: 10A • Diag. No.: D7A • Pick-up voltage: 75% of nominal or less @ 25°C • Duty cycle: Continuous.
Operational characteristics • Timing value: Operate time 20 ms; Release time 28 ms.
Insulation characteristics (Dielectric Strength) • Contact to coil: 2000 VRMS • Across open contacts: 500 VRMS • Pole to pole: 2000 VRMS • Contact to frame: 2000 VRMS.
Environmental characteristics • Operating: -30°C to +65°C • Non-operating (storage): -30°C to +100°C.
Product Details | |
Brand | NTE |
Model | R10-11D10-24 |
Part Number | 075-110 |
UPC | 768249012870 |
Unit of Measure | Each |
Weight | 0.2 |
Product Specifications | |
Coil Voltage | 24 VDCV |
