  • Light Dimmer 12-24 VDC 8A for Single Color LED Light Strips
CLEARANCE Light Dimmer 12-24 VDC 8A for Single Color LED Light Strips
Part #073-141
Part #073-141
Cut the brightness without a controller with this 12 to 24 VDC 8A light dimmer.
  • Reduce voltage for the perfect brightness
  • Screw terminals for easy installation
Use this light dimmer to bring down the brightness going into LED light strips that don't have a dimmer option. Programmable LED lights sometime leave off a dimmer option on the controller. Hooking this 12 to 24 VDC light dimmer between the power supply and the controller brings down the brightness of the preprogrammed light sequences. Single color LED light strips may not have a controller and this dimmer will bring the lights down to all the way off if needed. Make sure the lights strips don't draw more than 8A or the dimmer will burn out.
Specifications: Voltage input: 12 to 24 VDC • Maximum current output capability: 8A • Voltage output: Variable • Terminals: Slot screw phoenix sockets • Dimensions: 2-9/16" W x 3-1/2" H x 1-3/8" without knob and with mounting bracket •Mounting holes 5/32" Dia. and 3" vertical by 1-1/2" horizontal apart to center.
Part Number073-141
UPC848864060361
Weight0.17
MONSTER DEAL
OF THE WEEK
$45.98 EACH
SAVE $12
Dayton Audio KABD-250 2 x 50W All-in-one Amplifier Board with DSP and Bluetooth 5.0 aptX HD
