We use cookies to provide the best possible customer experience across this site, through third party ads and analysis of web data. By continuing you agree to our use of cookies and our overall privacy policy.
The Lepai LP7498E combines tremendous horsepower, Bluetooth freedom, and a handsome, dignified visual appeal. This mini amp supplies scandalous quantities of output power effortlessly, thanks to the TDA7498E amplifier chip. Meanwhile, the minimalist interface and clean, understated appearance lend a sense of luxury and cultivation to your audio system — and beyond.
200 watt Class D amplifier
Bluetooth atpX connection for high quality wireless music streaming
Compact size is perfect for home audio or multimedia systems
We'll send you an email when Lepai LP7498E 200W Class D Stereo Amplifier with Bluetooth aptX and Power Supply is back in stock or available for preorder.
Look no further, the Lepai LP7498E amplifier delivers a clean 200 watts from one of the most efficient Class D amplifiers in history! Use the Bluetooth aptX connection to wirelessly stream audio from your iPhone, Android smartphone, tablet, or laptop. The aptX codec produces the better quality sound than standard Bluetooth used with aptX compatible devices. With 100 watts per channel, this stereo amplifier is perfect for desktops, bookshelf speakers, and most home audio applications. The black chassis and a laser engraved silver faceplate provide a very attractive, modern finish.
High quality binding posts (5/8" on center) accept bare wire, 3/8" spade terminals, or standard banana plugs for problem-free speaker connections. RCA L/R inputs for analog connection (cable not included). Includes 36 VDC 4.5A power supply.
Specifications: • Power output (10% THD): 2 x 160 watts into 4 ohms, 2 x 120 watts into 6 ohms, 2 x 100 watts into 8 ohms • Amplifier efficiency: 90% • Minimum THD: <1% • Signal-to-noise ratio: >90 dB • Frequency response: 20-20,000 Hz • Bluetooth compatibility: Class 2 A2DP, AVRCP up to 20 meters • DC power input jack: 2.5 mm x 5.5 mm • Power requirements: 18 to 36 VDC, 4.5A • Included power supply: 110-240 VAC input, 36 VDC, 4.5A output • Dimensions: 4-1/2" W x 7" D x 1-1/4" H.
