Lepai LP-2020A+ Tripath Class-T Hi-Fi Audio Mini Amplifier with Power SupplyThe leading edge of a small-amplifier revolution
This special purchase Lepai Tripath-based mini audio amplifier is ideal for both home and car audio applications. The amplifier's TA-2020 amp chip is a 20W/ch. continuous average two-channel Class-T Digital Audio Power Amplifier IC that incorporates Tripath's proprietary Digital Power Processing™ technology. Class-T amplifiers offer the audio fidelity of Class-AB designs combined with the power efficiency of Class-D amplifiers. The Lepai amp's clean, 20 watt output makes it perfect for almost any auto or home audio project or DIY application.
Get connected quickly and start listening to music
Google "Lepai LP-2020A+" and you'll find this little amp has been discussed and raved about! Each unit has an RCA Left and Right channel input, or you can use the 3.5 mm stereo input jack for plugging in almost any music source, such as iPods, cell phones, or MP3 players. Convenient spring terminals make connections to your speakers quick and easy!
Arrives ready to work, and keeps on working
The Lepai mini amplifier has an aluminum enclosure that is lightweight, yet sturdy, and acts as a heat sink to keep the amp running cool. Color may vary. Includes at minimum 12V, 2A power supply. PSU styles may vary.
Specifications: • Power output: 2 x 20 watts RMS • Input impedance: 47k ohms • Frequency response: 20 Hz - 20 kHz • Input sensitivity: 200 mV • Minimum THD: <0.5% • Dimensions: 4.72" D x 5.79" W x 1.65" H.
Power Supply Specifications: • Input: 100~240 VAC, 50-60 Hz • Output: 12 VDC, 2A (minimum) • 2.1 x 5.5 plug.
