  • Speaker L-Pad Attenuator 15W Mono 3/8" Shaft 8 Ohm
Part #260-248
Part #260-248
L-pads adjust the relative volume of drivers connected to them by placing added resistance in series and parallel, keeping impedance a constant 8 ohm load. This L-pad is rated at 15 watts RMS, is designed to be used with 8 ohm loads, features a 3/8" shaft length, and comes with mounting hardware.
  • Easy level adjustment without changing impedance
  • Great for speaker design tweaking
  • Maintains 8 ohm impedance
  • Mounting hardware included
Your Price: $9.49
MSRP: $9.99
Save $0.50 (5%)
Quantity:Qty: 1-9 $9.49/ea
Quantity:Qty: 10+$8.49/ea
226In Stock
L-pads adjust the relative volume of drivers connected to them by placing added resistance in series. At the same time, a counter-resistance is placed in parallel with the driver to maintain a constant impedance which allows the original crossover design to be used. L-pads are to be placed in between the amplifier and driver, or in between the crossover and driver. This particular L-pad is rated at 15 watts RMS, is designed to be used with 8 ohm loads, features a 3/8" shaft length, and comes with mounting hardware, faceplate, and control knob.
Dimensions: 1-5/8" dia. x 15/16" D.
L-Pad Instruction Diagram
Part Number260-248
UPC844632017834
Weight0.11
MONSTER DEAL
OF THE WEEK
$189.00 EACH
SAVE 21%
Dayton Audio SPA250DSP 250W Subwoofer Plate Amplifier with DSP
