  • Knock-Down MDF 1.5 ft³ Subwoofer Cabinet for Dayton Audio 12" Reference Series HO
NEW Knock-Down MDF 1.5 ft³ Subwoofer Cabinet for Dayton Audio 12" Reference Series HO
Part #300-5014
Part #300-5014
Build a refined, musical subwoofer! All it takes is this 1.5 cubic foot subwoofer cabinet and the high-end Dayton Audio 12" Reference Series High Output subwoofer it was designed for. Assembles in minutes, just add wood glue.
  • 1.5 ft³ cabinet made of 3/4" MDF panels with a 1-1/2" thick front baffle
  • CNC-machined dadoes, subwoofer cutout and recess, and a unique bracing system that increases cabinet rigidity
  • Designed specifically for the Dayton Audio RSS315HO-4 12" subwoofer when used with a plate amp with bass boost
NEW $139.98
MSRP: $164.99
Save $25.01 (15%)
Order in the next 4 hr 8 min to ship today. Details
Even the easiest do-it-yourself subwoofer can turn into an arduous project; from uneven cuts, to measuring mistakes. CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills. This cabinet is designed for speaker builders and designers who don't have access to expensive tools or a woodshop.
This particular cabinet is designed specifically for the Dayton Audio RSS315HO-4 12" Reference Series High Output subwoofer, but works for any subwoofer with an overall diameter of 12-3/8" or less, and a cutout requirement of 11-1/8" or less. For optimum performance, the cabinet is oversized to allow for the use of a plate amplifier with bass boost (such as the Dayton Audio SPA250 or Dayton Audio SPA500 plate amplifiers) to extend the frequency response while staying musical.
During the CNC manufacturing process, rabbets dadoes are cut into the back and side panels ensuring precise alignment. A unique interlocking two-piece brace adds superior rigidity without affecting the subwoofer's performance. In addition, the initial baffle includes rabbets and dadoes ensuring perfect installation of the first part of the two-part, double thick baffle. Plate amplifier installation is made easy by following the scribed interior guide with a jig saw (scribed amplifier cutout is for the Dayton Audio SPA500 or SPA250).
The end result is a resonance-free, sealed subwoofer cabinet that is purpose-built to extract the best performance from Dayton Audio's 12" Reference Series High Output subwoofer. All that's left to do is finish it to match your décor or paint it to stand out. When your friends ask about it, you get the pleasure of saying, "I built it myself!"
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle, bracing, and subwoofer volume): 1.5 cubic feet • External dimensions: 15.5" H x 15.5" W x 16.5" D • Subwoofer recess: 1/2" • Weight: 37 lbs. • Made in the U.S.A.
Part Number300-5014
UPC848864075693
Weight29.6
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
