  • Kicker Comp-15 15" Subwoofer 4 Ohm
CLEARANCE Kicker Comp-15 15" Subwoofer 4 Ohm
Kicker
Part #267-598
Kicker
Part #267-598
Model: Comp-15
Kicker's C15 15" 4 ohm Comp Series subwoofer features elite Kicker construction and is built for maximum bang-for-your-buck!
  • A ribbed, UV-treated surround with white double stitching binds the suspension to a thick polypropylene cone for excellent reliability
  • The basket uses high-quality stamped steel for outstanding stability under extreme stress
  • The bumped back plate allows the high-temp voice coil to move even more, so you get deeper bass without distortion
  • Perimeter venting allows air to move freely around the motor for excellent heat management
  • A stiff injection-molded cone with 360-degree back bracing keeps the bass smooth and loud all day long
  • The spring-loaded, satin nickel terminals accept a wide range of speaker wires
Kicker Comp™ Subwoofer Series delivers the best bass for the buck! Legendary Kicker bass and possibly the world’s greatest value for under $170. The Comp Series is the best balance between high value and high performance in Kicker’s lineup. All Comp Series subwoofers are versatile, performing in vented or sealed enclosures, and in free-air applications as well.
The C15 Comp Series 15", 4 ohm subwoofer is equipped with all of the proven Kicker construction that you find in elite Kicker woofers, including: the stiffest injection-molded cone with flex-killing 360° back bracing, coil cooling perimeter venting, high-temp voice coil wire, and Spiralead™ tinsel-lead technology for ultimate durability.
Easy-to-use nickel-plated push terminals, a resilient steel basket, and white double-stitched surround make Kicker's C15 subwoofer look as good as it sounds. If all of this isn't enough... the C15 leaves enough cash left over to throw down on a powerful Kicker amplifier to unlock optimum subwoofer performance.
BrandKicker
ModelComp-15
Part Number267-598
UPC713034078654
Weight17.65
Nominal Diameter15"
Power Handling (RMS)250 Watts
Power Handling (MAX)500 Watts
Sensitivity90.3dB 2.83V/1m
Resonant Frequency (Fs)23Hz
DC Resistance (Re)3.32Ω
Mechanical Q (Qms)9.607
Electromagnetic Q (Qes)0.422
Total Q (Qts)0.404
Compliance Equivalent Volume (Vas)7.99ft³
Maximum Linear Excursion (Xmax)13.5mm
Overall Outside Diameter15.50"
Baffle Cutout Diameter13.69"
Depth7.44"
Sealed Volume2.25ft³
Sealed F346Hz
Vented Volume4ft³
Vented F334.3Hz
