  • J.A.L. Electronics JAL803 8" Mid Woofer 4 Ohm
BUYOUT J.A.L. Electronics JAL803 8" Mid Woofer 4 Ohm
Factory Buyouts
Part #299-4202
Factory Buyouts
Part #299-4202
Model: JAL803
A full range, wide dispersion loudspeaker ideally suited to voice paging, background music and fire alarm signaling. 8" full range speaker with whizzer cone, 3 oz. ceramic magnet, 3/4" aluminum voice coil.
BUYOUT $4.88
132In Stock
A single-piece paper cone and surround assembly helps reduce unwanted resonances and keeps excursion under control. A whizzer cone helps extend high frequencies to above 8,000 Hz. This lightweight 8" full range speaker is a great replacement option for many PA applications, or as a dedicated midrange speaker in a budget speaker system.
BrandFactory Buyouts
ModelJAL803
Part Number299-4202
UPC848864073484
Weight1
Nominal Diameter8"
Bolt Circle Diameter7
Power Handling (RMS)12 Watts
Power Handling (MAX)24 Watts
Frequency Response90 to 6,000Hz
Sensitivity85.77dB 2.83V/1m
Voice Coil Diameter0.75"
Resonant Frequency (Fs)91.28Hz
DC Resistance (Re)3.483Ω
Voice Coil Inductance (Le)0.1507mH
Mechanical Q (Qms)13.14
Electromagnetic Q (Qes)7.914
Total Q (Qts)4.939
Compliance Equivalent Volume (Vas)0.8972ft³
Diaphragm Mass Inc. Airload (Mms)8.864g
Maximum Linear Excursion (Xmax)1.5mm
Surface Area of Cone (Sd)232.4cm²
Cone MaterialPaper
Surround MaterialPaper
Voice Coil FormerPaper
Overall Outside Diameter8.125"
Baffle Cutout Diameter7.25"
Depth2.625"
MONSTER DEAL
OF THE WEEK
$129.49 EACH
SAVE $14
Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
