  • Infinity VRS2 5" Terminal Cup with 2-Way Crossover
BUYOUT Infinity VRS2 5" Terminal Cup with 2-Way Crossover
Factory Buyouts
Part #299-224
Factory Buyouts
Part #299-224
Model: VRS2
The Infinity VRS2 5" Terminal Cup with 2-Way Crossover not only makes for an ideal replacement in the Infinity VRS2 speaker, but will work well as a beginner crossover in a small 2-way custom design.
  • 2-way, second order filter for a 3kHz crossover point using 8 ohm drivers
  • I-Core inductors for decreased DCR
  • Integrated variable L-pad for high frequency fine-adjustment
  • 100W RMS power handling
BUYOUT $6.88
Quantity:Qty: 1-63 $6.88/ea
Quantity:Qty: 64-127 $6.12/ea
Quantity:Qty: 128+$5.85/ea
Order in the next 0 hr 38 min to ship today. Details
160In Stock
The Infinity VRS2 5" Terminal Cup with 2-Way Crossover makes design work easy, and installation easier. The 5-1/4" diameter cup mounts into a 4-1/8" diameter hole and comes complete with a 12dB 2-way crossover and variable high frequency L-Pad, giving you a 3kHz crossover frequency using 8 ohm drivers. Iron core inductors, electrolytic capacitors and ceramic resistors make up the crossover components. 14.5" long high frequency and 18" long low frequency leads for simple installation. 100W power handling.
ModelVRS2
Part Number299-224
UPC656403111272
Weight0.55
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
