High Power RGB LED 12-24 VDC 12A Slim Control Unit with 18-Key Magnetic Mounting RF RemoteHook up to 180W of RGB LED light strips to this 12 VDC 15A controller with RF remote. That's approximately 50 ft. of LED strips (3 x 16.6 ft.) at one time. It's recommended that you start each light strip at the controller to maintain color integrity. The controller works 5 to 24 VDC LED light strips also, but the wattage different, so make sure you match the power supply to your LED light strip voltage and wattage requirements within the controller's specifications. The controller has two screw holes 0.113" (3 mm) Dia. and 2.83" (72 mm) apart from center for mounting. Recommend #4 screws sold separately.
A 18-key RF remote control is included for quickly powering LED strips on or off, changing through millions of different colors, controlling brightness, or for using one of the 34 built-in color loop modes. The RF remote enables you to hide the controller and power supply out of sight. The remote comes with a small piece of metal with peal-and-stick adhesive on one side to adhere to an appliance, cabinet, or door jam. Once you put the piece of metal in a convenient location, place the remote on it and the magnet in the remote holds it there until ready to use.
On top of the controller is a built-in work status light. This light informs you if the controller's receiving a signal from the remote, power status, brightness and speed limit, overload protection, over heat protection, and new remote paired status. Check the attached manual for complete instructions.
Note: When using multiple controllers with one remote, make sure all controllers are in the same mode when reprogramming them to one remote.
Specifications: • Working voltage: 5 to 24 VDC • Output current: Up to 5A x 3 • Peak power handling: 75W (5V), 180W (12V), 360W (24V) • Dynamic mode: 34 modes • Speed grade: 10 levels • Static color: 30 colors • Color brightness grade: 5 levels • PMW grade: 4,000 steps: Remote frequency: 433.92 MHz • Remote control distance: >15m at open area • Remote dimensions: 3.43" H x 1.42" W x 0.315" D (87 x 36 x 8 mm) • Control dimensions: 3.43" H x 0.95" W x 0.59" (87 x 24 x 15 mm) • Certification: CE, RoHS • Included remote battery: CR2032.
