  • HiVi C1900II 5-1/4" 2-Way Component Speaker Set
CLEARANCE HiVi C1900II 5-1/4" 2-Way Component Speaker Set
HiVi
Part #267-4364
HiVi
Part #267-4364
Model: C1900II
The HiVi C1900II is a beautiful 5-1/4" 2-way component set that is ideal for the car audio minimalist seeking audiophile quality.
  • Water and moisture-proof woofer cone
  • Fatigue-resistant rubber surround
  • Unique tweeter mounting hardware included
  • Well-designed, enclosed crossovers included
HiVi's C1900II is a 5-1/4" 2-way car audio components set. This set contains two woofers, two tweeters, two crossovers, and various accessories.
The woofer in this component set utilizes a polypropylene cone and a high-performance motor structure
The tweeter features a silk diaphragm, ferrofluid, and unique mounting hardware.
Complete Set Specifications: • Power handling: 100W RMS, 200W Max • Impedance: 4? • Frequency response: 73-20,000 Hz
Tweeter Specifications: • Impedance: 4 ohms • Re: 3.54 ohms • Fs: 1594 Hz • Le: 0.048 mH • Frequency range: 3,000-20,000 Hz • SPL: 91 dB @ 1W/1m.
Woofer Specifications: • Impedance: 4 ohms • Re: 3.26 ohms • Fs: 73.35 Hz • Le: 0.51 mH • Frequency range: 73-4,500 Hz • Qts: 0.625 • Qes: 0.715 • Qms: 4.96 • Mms: 8.77 g • Vas: 5.66 L • SPL: 90.7 dB @ 1W/1m • Overall Diameter: 5.43" • Cut-out Diameter: 4.56" • Mounting Depth: 2.44".
BrandHiVi
ModelC1900II
Part Number267-4364
UPC848864055428
Weight7.05
Speaker Size5.25"
Speaker TypeComponent System
Power Handling (RMS)100 Watts
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
