  • HiVi B2S 2" Shielded Aluminum Driver
HiVi
Part #297-432
HiVi
Part #297-432
Model: B2S
HiVi B2S 2" drivers are capable of covering a wide portion of the audio spectrum, and are easy to install without the need for cutting complicated driver recesses.
Your Price: $13.98
MSRP: $18.99
Save $5.01 (26%)
Quantity:Qty: 1-3 $13.98/ea
Quantity:Qty: 4-9 $13.28/ea
Quantity:Qty: 10+$12.58/ea
Order in the next 13 hr 17 min to ship today. Details
8In Stock
Magnesium/aluminum alloy concave cones and square frames are the distinguishing features of the BS Series. HiVi B2S 2" drivers are capable of covering a wide portion of the audio spectrum, and are easy to install without the need for cutting complicated driver recesses. Magnetically shielded design allows use in center channel and other multimedia applications. Stamped steel frame and rubber surround.
BrandHiVi
ModelB2S
Part Number297-432
UPC844632022579
Weight0.28
Nominal Diameter2"
Power Handling (RMS)10 Watts
Power Handling (MAX)20 Watts
Frequency Response150 to 15,000Hz
Sensitivity78dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)152Hz
DC Resistance (Re)6.5Ω
Mechanical Q (Qms)5.69
Electromagnetic Q (Qes)1.53
Total Q (Qts)1.2
Compliance Equivalent Volume (Vas)0.007ft³
Mechanical Compliance of Suspension (Cms)0.689mm/N
BL Product (BL)2.5T·m
Maximum Linear Excursion (Xmax)1.5mm
Surface Area of Cone (Sd)13cm²
Cone MaterialAluminum / Magnesium
Voice Coil Wire MaterialCCA
Magnet MaterialNeodymium
Overall Outside Diameter2.13"
Baffle Cutout Diameter1.875"
Depth1.25"
Sealed Volume0.02ft³
Sealed F3131.8Hz
Vented Volume0.04ft³
Vented F3106.6Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
