  • Gemini GMU-HSL100 Professional Wireless Headset and Lavalier Rechargeable Battery Body Pack
Gemini
Part #235-162
Gemini
Part #235-162
Model: GMU-HSL100
The GMU-HSL100 is a complete UHF Wireless System that includes both a dynamic headset microphone and a lavalier microphone with a wireless transmitter bodypack and receiver with a 1/4” connection. This expandable Plug & Play system will meet all your wireless needs, with a USB rechargeable receiver and long-distance wireless connection. Just plug in and power on, and you’re ready to rock.
  • Complete UHF wireless system with headset and lavalier microphones
  • USB rechargeable receiver with over 164' of wireless range
  • Body pack transmitter with easy-to-read LED display and AA batteries included
  • Wide range of UHF frequencies for interference-free operation (US: 512-541.7MHz, Europe: 863-865MHz)
  • Supports up to 6 pairs of devices working simultaneously without interference
  • Ability to transmit one signal to multiple receivers simultaneously
  • Perfect for karaoke, busking, weddings, conferences, streaming, podcasting, and more
Your Price: $49.95
MSRP: $79.95
Save $30.00 (38%)
The GMU-HSL100 is a complete UHF Wireless System that includes both a dynamic headset microphone and a lavalier microphone with a wireless transmitter bodypack and receiver with a ¼” connection. This expandable Plug & Play system will meet all your wireless needs, with a USB rechargeable receiver and long-distance wireless connection. Just plug in and power on, and you’re ready to rock. Choose either the lavalier or headset mic depending on your preference and connect to the Body Pack Transmitter. AA batteries are included. Gemini’s GMU Wireless system is perfect for many applications, including but not limited to karaoke, busking, weddings, conferences, streaming, and podcasting. We’ve put our years of audio industry experience into developing a high-quality wireless system that only Gemini can provide.
Easily connect the headset or lavalier microphone to the Body Pack and wirelessly link to the R10 Receiver for an untethered audio connection in a variety of settings, from music performances to weddings and conferences. With a stable signal and no delay, the wireless range extends over 164 feet, ensuring you stay connected. The R10 Receiver contains a rechargeable lithium battery that conveniently charges via USB with the included Micro-USB cable, providing hours of use on a single charge. Monitor remaining battery life and channel/frequency via the Body Pack’s easy-to-read LED display.
The GMU-HSL100’s versatile design makes it ideal for numerous applications. Whether in a professional environment or at home, the GMU Series offers the perfect solution for your wireless audio needs. The transmitter and receiver automatically pair—just connect the desired microphone to the Body Pack, plug the receiver into your audio device, and power on. Changing frequencies is easy with the Body Pack, ensuring you find an interference-free channel.
Additionally, the GMU Wireless System supports up to six pairs of devices working without interference and can transmit one signal to several receivers simultaneously. This flexibility, combined with its high-quality audio performance, makes the Gemini GMU-HSL100 the ultimate choice for all your wireless audio needs.
Highest Sensitivity
The Gemini GMU lapel mic features a highly sensitive polar pattern that captures your voice effortlessly, allowing you to focus on delivering your message or performance without concern for projection.
Be Heard
The GMU wireless series offers expandability, supporting up to six different receivers when connected to multiple inputs such as PA speakers or mixers.
Easy Set Up
Straight out of the box, the transmitter and receiver automatically sync upon powering up, enabling instant use without the need for manual pairing.
Versatile
Wherever your performance takes you, enjoy the confidence of clear and reliable wireless audio that keeps your sound uninterrupted.
Go the Distance
With an extended range of up to 164 feet, you have the freedom to take over an entire park or block, performing without limitations or signal dropouts.
East Connect
Equipped with a 1/4-inch jack receiver, this system easily connects to PA speakers, mixers, or amplifiers, ensuring a quick and hassle-free setup for any event or scenario.
  • Polar Pattern: Cardioid
  • Wireless Range: 50 Meters / 164 Feet
  • Distortion: <0.6%
  • Dynamic Range: ≥ 106 dB
  • Frequency Range: R2 (USA): 512-541.7MHz
  • Frequency Response: 20Hz-18KHz, +1dB/-3dB
  • Construction Material: ABS Plastic
  • Microphone Battery: AA (Batteries Included)
  • Receiver Battery: 500mAh Rechargeable Lithium
  • Charging: Micro-USB
BrandGemini
ModelGMU-HSL100
Part Number235-162
UPC747705007803
Weight0.6
