  • Gator Frameworks GFW-SPK-WM100 Speaker Wall Mount Pair
$84.99
Free Shipping available on orders over in the US. Details
The GFW-SPK-WM100 by Gator Frameworks includes a pair of robust wall mounts for your pro audio or commercial speakers. Loaded with features, these mounts punch way above their weight class when it comes to overall value. Heavy duty construction means each mount can hold a speaker up to 100 pounds (45 kg). These mounts are also very adjustable, with adjustments to allow for aiming the speaker precisely where you need it. Both the horizontal and vertical position can be adjusted through a wide range. An adjustable base plate secures the speaker even further, and the plate has a rubberized surface so it won't mar the finish on your speaker.
Specifications: • Min height: 26" • Min width: 5.5" • Max width: 12" • Speaker mount diameter: 1.38" • Weight capacity: 100 lbs. • Weight: 5 lbs.
Gator Cases is proud to introduce the Frameworks line of stands and support equipment for working musicians, students, production companies, houses of worship, and any others interested in a refreshing change in the status quo of such products. Frameworks stands are high quality gear, minus the high prices generally associated with this level of durability and user-friendliness. Try a Frameworks stand today, and we think you'll agree: there's no longer any reason to overpay for underperforming stands!
