  • GRS PT6816-8 8" Planar Slim Tweeter 8 Ohm
GRS
Part #272-128
GRS
Part #272-128
Model: PT6816-8
Capable of delivering wide bandwidth with low distortion, the GRS PT6816-8 open back planar driver has the ability to perform well from upper midrange to the highest frequencies. With an extremely lightweight diaphragm and a neodymium motor system, this driver is capable of excellent transient response with amazing dynamics. The open back construction produces true dipole radiation which is ideal for use in open baffle designs. With a narrow footprint and minimal flange, the PT6816-8 is also ideal for line array use.
  • Extremely low mass diaphragm provides excellent transient response and accuracy
  • Narrow design to deliver excellent off axis consistency
  • Multiple neodymium magnets in push pull arrangement for incredible control and low distortion
  • Open back delivers true dipole radiation making this driver ideal for open baffle line array designs
  • Linear impedance simplifies crossover design
  • Shallow mounting depth for use in low profile designs
  • Custom mounting faceplate available
Your Price: $49.98
MSRP: $71.99
Save $22.01 (31%)
Quantity:Qty: 1-3 $49.98/ea
Quantity:Qty: 4+$44.98/ea
Free Shipping available on orders over $49.00 in the US. Details
Designed to deliver high efficiency with extremely smooth response.
With wide dispersion capabilities and minimal mounting flange, the PT6816-8 is an excellent choice for use in high output line arrays. The open-back design gives this tweeter true dipole radiation making it the perfect choice for use in open baffle speaker designs.
Key Specs:
  • Tweeter Type: Planar Magnetic
  • Power Handling (RMS): 35 Watts
  • Power Handling (MAX): 70 Watts
  • Impedance:
  • Frequency Response: 500 - 20,000 Hz
  • Sensitivity: 94dB 2.83V/1m
  • Diaphragm Material: Polyethylene Naphthalate
Full SpecificationsManual
Frequency Response & Impedance
Thanks to a lightweight damped polyimide diaphragm that is driven by 18 powerful neodymium magnets in a push-pull arrangement, this driver is capable of incredible transient response and wide bandwidth. The almost linear 6.4 ohm impedance makes crossover design simple and minimizes the number of components required to achieve your required roll off.
Optional Faceplate Available
Add the final touches to any build that uses the PT6816-8 with the optional faceplate! When the tweeter is attached to the faceplate, the resulting shape is easier to flush mount into your speaker baffle, creating a clean aesthetic and reducing diffraction.
Buy Now!
Shop all GRS Planar Tweeters and Faceplates
GRS Planar Tweeters provide great transients, and frequency response at the fantastic value you expect from GRS
GRS PT2522-4
Nominal Impedance: 4ohm
Frequency Response: 1800-20kHz
Buy Now
GRS PT6825-8
Nominal Impedance: 8ohm
Frequency Response: 250-20kHz
Buy Now
GRS PT6816-8
Frequency Response: 320-20kHz
Buy Now
GRS PT5010-8
Frequency Response: 200-8kHz
Buy Now
GRS PT2522-FP Face Plate for PT2522-4 and PT2522C-4
Buy Now
GRS PT6825-FP Face Plate for PT6825-8 Planar Tweeter
Buy Now
GRS PT6816-FP Face Plate for PT6816-8 Planar Tweeter
Buy Now
GRS PT5010-FP Face Plate for PT5010-8 Planar Tweeter
Buy Now
BrandGRS
ModelPT6816-8
Part Number272-128
UPC848864061245
Weight0.8
Cutout Diameter6.89" x 1.65
Tweeter TypePlanar
Power Handling (RMS)30 Watts
Frequency Response320 to 20,000Hz
Sensitivity94dB 2.83V/1m
DC Resistance (Re)6.4Ω
Mechanical Q (Qms)6.19
Total Q (Qts)4.57
Overall Outside Diameter7.875" x 2.56"
Depth0.47"
MONSTER DEAL
OF THE WEEK
$14.99 EACH
SAVE 33%
Peerless by Tymphany OC25SC65‑04 1" Textile Dome Tweeter
