Factory assembled and pre-tested to pass the highest quality standards. Compact 11" diameter is less conspicuous than comparable models. The SDT4-CR8 utilizes a molded polystyrene grill with a non-glare ceiling white texture. It has an impedance of 8 ohms and is rated at 15 watts. The SDT4-CR8 is fitted with a 25/70 volt transformer.
Speaker Model #Q88D10 | Transformer Model T427 | ||
Size & Style | 8" Round | Power Rating | 4 Watts |
Magnet Weight & Type | 10 oz. Ceramic | Primary Voltage | 25 & 70 |
Speaker Type | Dual Cone | Insertion Loss @ 1 KHz | 0.9 dB |
Power Rating | 25 Watts | Frequency Response | 80-20,000 Hz |
Sensitivity | 100 dB | Primary Taps | 4, 2, 1, 1/2 Watts |
Response | 30-19,000 Hz | Primary Leads | 6" Color Coded |
Impedance | 8 Ohms | Secondary Impedance | 8 Ohms |
Coil Diameter | 1" | Secondary Leads | 6" Color Coded |
Depth | 2-7/8" | Mounting Centers | 2" |
Weight | 2.1 Lbs. | Weight | 0.42 Lbs. |
Product Details | |
Brand | Fourjay Industries |
Model | SDT4-CR8 |
Part Number | 300-350 |
UPC | 844632007552 |
Unit of Measure | Each |
Weight | 4.1778 |
Product Specifications | |
Input Rating | 8 ohm|70V|25V |
Mounting Style | In-ceiling |
Woofer Diameter | 8" |
