Designed for paging and music in moderately noisy environments, the Little Big Horn provides pleasing voice projection and high speech intelligibility. Constructed of impact & UV resistant ABS and stainless steel fasteners, it is weather and corrosion resistant while the reflex driver uses a moisture resistant diaphragm. The adjustable mounting base will attach to a 3" electrical box or it may be recess mounted; the hole locations are provided on the flange. Tan in color. Made in the USA.
Specifications: • Rated input: 70.7V line • Power taps: 6, 3, 1 & 1/2 watts • Frequency range: 400-5,000 Hz • Sensitivity: 97 dB • Mfg. #306/70-T • Dimensions: 5-1/2" W x 5-1/2" H x 4-1/2" D (excluding mounting base).
Product Details | |
Brand | Fourjay Industries |
Model | 306/70-T |
Part Number | 300-064 |
UPC | 844632007323 |
Unit of Measure | Each |
Weight | 1.75 |
Product Specifications | |
Speaker Type | PA Horn Speaker |
