  • Fourjay 132-TD 25/70V Re-Entrant Horn Speaker
Fourjay Industries
Part #300-069
Model: 132-TD
Designed for noise penetration and clear speech intelligibility, the 132-TD is used in high-noise areas and outdoor locations where you need exceptionally high output and long-throw coverage. It also boasts excellent sensitivity as a microphone in talk-back systems.
Your Price: $145.98
MSRP: $188.99
Save $43.01 (23%)
Quantity:Qty: 1-5 $145.98/ea
Quantity:Qty: 6+$138.68/ea
Designed for noise penetration and clear speech intelligibility, the 132-TD is used in high-noise areas and outdoor locations where you need exceptionally high output and long-throw coverage. It also boasts excellent sensitivity as a microphone in talk-back systems. It is conservatively rated at 32 watts continuous duty while the diffuser suppresses on-axis hot spot and improves dispersion. Weather and corrosion resistant construction uses stainless steel fasteners and engineering grade UV resistant thermoplastics. Unique mounting design offers quick, easy assembly and adjustment. Includes 18-2, black jacketed, 3 ft. cable for fast "hard wiring" and good weatherability. Made in the U.S.A.
Specifications: • Input: 25V or 70.7V line • Power taps: 32, 16, 8, 4 & 2 watts • Frequency range: 600- 4,500 Hz (±3 dB) • SPL: 110 dB 1W/1m.
BrandFourjay Industries
Model132-TD
Part Number300-069
UPC844632007354
Weight4.5
Speaker TypePA Horn Speaker
