  • Foster 96D9405 2-1/2" Paper Cone Mini Speaker 8 Ohm
BUYOUT Foster 96D9405 2-1/2" Paper Cone Mini Speaker 8 Ohm
1 Question, 1 Answer or
Factory Buyouts
Part #299-4150
Factory Buyouts
Part #299-4150
Model: 96D9405
The Foster 96D9405 2-1/2" Paper Cone Mini Speaker is a perfect replacement option for many PC's and clock radios.
BUYOUT $0.88
Quantity:Qty: 1-49 $0.88/ea
Quantity:Qty: 50-99 $0.58/ea
Quantity:Qty: 100+$0.48/ea
77089In Stock
This Foster 96D9405 2-1/2" Paper Cone Mini Speaker is a perfect replacement option for many PC's and clock radios. Designed to be surface or rear mounted, this 2-1/2" mini speaker has a shallow mounting depth for numerous applications. Integrated 3" long wire leads make installation a breeze.
BrandFactory Buyouts
Model96D9405
Part Number299-4150
UPC848864072357
Weight0.18
Nominal Diameter2-1/2"
Power Handling (RMS)2 Watts
Power Handling (MAX)4 Watts
Frequency Response300 - 15,000Hz
Sensitivity82.77dB 2.83V/1m
Voice Coil Diameter0.5"
Resonant Frequency (Fs)299.9Hz
DC Resistance (Re)7.867Ω
Mechanical Q (Qms)15.81
Electromagnetic Q (Qes)4.697
Total Q (Qts)3.621
Compliance Equivalent Volume (Vas)0.007ft³
Diaphragm Mass Inc. Airload (Mms)1.048g
Surface Area of Cone (Sd)23.76cm²
Cone MaterialPaper
Surround MaterialPaper
Voice Coil FormerPaper
Overall Outside Diameter2.625"
Baffle Cutout Diameter2.375"
Depth0.75"
