  • Fosi Audio V3 Stereo Amplifier 300W x 2 with 48V Power Supply
NEW Fosi Audio V3 Stereo Amplifier 300W x 2 with 48V Power Supply
Read 1 Review or
Fosi Audio
Part #235-266
Fosi Audio
Part #235-266
Model: V3
Read 1 Review or
The Fosi Audio V3 is a high-performance stereo amplifier that delivers exceptional sound quality in a compact, stylish design. Ideal for home audio systems, it offers advanced thoughtful engineering, multiple power supply options, and built-in heat dissipation features for reliable and safe operation. Experience rich, immersive audio with the Fosi Audio V3, perfect for music, movies, and gaming.
  • The compact and simple design will fit in on any bookshelf, desktop, or home theater setup
  • Trade out the power supply to get the power output that suits your needs best
  • Advanced design features and vents in the casing, this amp dissipates heat like no other
  • A TI TPA3255 amp chip and an array of Japanese and German components mean this amp only delivers the best sound quality
  • 3.5mm pre-out gives the option of adding an active subwoofer
  • 48V 5A power supply included
NEW $109.99
Elevate your audio experience with the Fosi Audio V3, a compact yet powerful stereo amplifier designed to deliver pristine sound quality. Whether you're a veteran or only beginning to dip your toes into high quality audio equipment, the V3's high-fidelity stereo sound means every note and beat is delivered with precision, making your music, movies, and games come to life. Its sleek design not only looks stylish but also guarantees durability, fitting effortlessly into any room in your home.
 The Fosi Audio V3 is engineered with Japanese NCC, ELNA, and German WIMA capacitors, and Japanese Sumida inductors for exceptional audio quality. It supports multiple power supply options, providing the flexibility to change to a different power supply for different power outputs. Plus, the built-in overheat protection offers reliable and safe operation, so you can enjoy exceptional sound quality worry-free. A 3.5mm pre-out jack offers the option to expand your system with an active subwoofer. Please note the pre-out level is NOT controlled by the volume control as the V3 is not an integrated amplifier, so the sound is NOT adjustable when you are connected to the "Pre-out".
  • Chip Set: TI TPA3255
  • Terminating Impedance: 2-8 Ohms
  • Input Mode: RCA
  • Output Mode: Speaker Output + Pre-out
  • Frequency Range: 20Hz-20kHz (±0.1dB)
  • SINAD: 88dB
  • Total Harmonic Distortion (THD): 0.003%
  • Signal-to-Noise Ratio (SNR): ≥110dB
  • Control Knob: Built-in Logarithmic Taper A pot
  • Device Dimension: 6.5 x 4.1 x 1.4 inches
  • DC Input Range: 24-48V
  • Power Supply: 32V/5A, 48V/5A
BrandFosi Audio
ModelV3
Part Number235-266
Weight2.53
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
