  • FootNote Electric Guitar 5 Watt Amp Assembly - No Power Supply
CLEARANCE FootNote Electric Guitar 5 Watt Amp Assembly - No Power Supply
Factory Buyouts
Part #249-402
Factory Buyouts
Part #249-402
You can build your own practice amp, to your liking, for a mere fraction of the price you'd pay for a "store-bought" model. The FootNote is 5 watt amp module packed with extras, from a very reputable manufacturer. We have a very limited quantity of these components available, so act fast!
  • Build it yourself, just the way YOU want it!
  • 5 watt amp module with cable tester and eight 9V power outputs
  • Headphone output and auxiliary input
  • External speaker output and line output
  • Buyout - extremely limited supply available
The FootNote amplifier module's main feature is a clean 5 watt amp with bass, treble, and volume control in a convenient form factor, but it doesn't stop there. With the FootNote, you also get a headphone output for private practice or listening, and an external speaker output to drive another speaker (4 ohm minimum impedance). But wait, there's more! You also get a line level output to feed your shredness directly to your mixing console, recorder, what have you. There is an auxiliary input for your iPod, smartphone, or other media device, so you can jam along with all your favorite tunes, AND, there's a super-handy cable tester built right in, so you never have to worry about bringing down the energy of your performance due to a bad cable.
As if all that weren't already awesome enough, there is more. The FootNote operates on 9 VDC 2.1 x 5.5 mm tip negative plug, has an optional input for battery power, and has eight (8) DC power output jacks built in to power your effects pedals! Recomended power supply 120-060 .
Snag one of these while you can. We have very limited quantities in stock, and once they're gone, they're gone!
Specifications: • Amp module dimensions: 12" L x 3-1/2" H x 2-9/16" D • Cutout: 11-9/16" L x 2-5/8" H • Power output: 5 watts • Inputs: 1/4" guitar / pedal; 3.5 mm aux; 1/4" x 2 cable tester • Outputs: 1/4" line; 1/4" ext speaker; 8 x 3.5 mm 9 VDC (center negative polarity) • Controls: main power on/off; line out on/off; volume, bass, and treble • Power input: 9 VDC (AC adapter not included) • Power output: 9 VDC x 8 (center negative polarity).
BrandFactory Buyouts
Part Number249-402
UPC848864023595
Weight1.3
MONSTER DEAL
OF THE WEEK
$45.98 EACH
SAVE $12
Dayton Audio KABD-250 2 x 50W All-in-one Amplifier Board with DSP and Bluetooth 5.0 aptX HD
