The FiiO A1 portable headphone amplifier sets a new standard for size and performance. Increase your volume and improve audio performance from any mobile device. Operation is easy and intuitive – there's a 3.5 mm stereo input and output, a volume control, and a power button. The power button also selects between four EQ options. Easily identify what EQ mode is selected with the LED indicator light.
The sleek, sandblasted aluminum alloyed casing gives the A1 a durable, modern look, and is comfortable to hold. A Micro USB port located on the bottom of the A1 allows you to recharge the onboard Li-Po battery in 90 minutes for 13 hours of playtime. Attach the A1 onto your clothing or to a lanyard and take it everywhere you go with the transparent, removable back clip.
Specifications: • Output power: ≥78 mW (16 ohms) • SNR: ≥100 dB (A weight) • THD+N: <0.05% (1 kHz) • Frequency response: 10 - 90,000 Hz • Input sensitivity: 1.05 Vrms • Crosstalk: ≥65 dB • Gain: 3.65 dB • EQ modes: Flat, Bass1 (2.7 dB bass boost), Bass2 (5.2 dB bass boost), Bass3 (5.2 dB bass reduction) • Battery capacity: 160 mAh • Charge time: ≤90 minutes • Play time: ≥13 hours (32 ohms loaded) • Headset impedance: 16 - 100 ohms • Micro USB power supply port: 5 VDC/1 A • Dimensions: 1.65" x 1.60" x 0.37".
