  • FX Audio DAC-X6 Hi-Fi 24-bit/192 kHz DAC with Headphone Output Black
CLEARANCE FX Audio DAC-X6 Hi-Fi 24-bit/192 kHz DAC with Headphone Output Black
FX Audio
Part #230-269
FX Audio
Part #230-269
Model: DAC-X6
The FX-Audio DAC-X6 digital to analog converter high resolution audio for an audiophile level sonic listening experience. A variety of inputs including optical, coaxial, and USB give you the ability to connect to a wide array of devices. With a sample rate of up to 24-bit/192 kHz, the DAC-X6 is the ideal DAC for your digital audio system.
  • High-fidelity DAC with conversion rates of up to 24-bit/192 kHz for superb audio quality
  • Flexible inputs including optical, coaxial, and USB-B provide the ability to connect to a variety of sources
  • Independent headphone amp delivers an audiophile sonic experience
The FX-Audio DAC-X6 digital to analog converter provides outstanding audio-fidelity for an audiophile level sonic experience. A variety of inputs including optical, coaxial, and USB give you the ability to connect to a wide array of devices. With a sample rate of up to 24-bit/192 kHz, the DAC-X6 is the ideal DAC for your digital audio system.
High-performance chipsets ensure that the digital to analog conversion of the DAC-X6 is of the greatest audio fidelity. Sample rates of up to 24-bit/192 kHz means that your sonic experience will be clear, crisp, and full. With the USB-B connection, you can plug the DAC directly into your PC or phone/tablet with OTG audio output.
In addition to stereo RCA output the DAC also features a 1/4" jack on the front panel. Utilizing an independent headphone amp, the DAC-X6 delivers superb audio fidelity for an all-encompassing, immersive headphone experience. The front panel also features a large volume control as well as input select.
Digital inputs: Optical, coaxial, PC USB-B
Outputs: Stereo RCA, 1/4" (6.35 mm) headphone
RCA line level output: 1.8 Vrms
Headphone max output: 281 mw @ 16 ohms, 222 mW @ 32 ohms, 144 mW @ 64 ohms, 38 mW @ 300 ohms
Headphone impedance: 32-600 ohms
THD: 0.001%
SNR: -94 dB
Chipset: OPA2134PA+6120A2+CS4398+SA9023+OP275G
USB sample rate: 24-bit/96 kHz, 16-bit/192 kHz
Optical/coaxial sample rate: 24-bit/192 kHz (Note: Please choose PCM format when using Optical or Coaxial input)
Power supply: 12 VDC, 1A (included)
Dimensions: 5.79" x 3.82" x 1.26" (147 x 97 x 32 mm)
BrandFX Audio
ModelDAC-X6
Part Number230-269
Weight1.35
