  • Eminence S2B-A Aluminum 1-3/8"-18 TPI Screw-On to 2/3-Bolt Horn Adapter
Eminence Speaker
Part #290-561
Eminence Speaker
Part #290-561
Model: S2B-A
Convert a 1-3/8"-18 TPI screw-on compression driver for use with a 2 or 3-bolt 1" horn, or waveguide, with Eminence's S2B-A adapter.
  • Adapts 1-3/8"-18 TPI screw-on compression drivers for use with 2/3-bolt horns and waveguides
  • Robust cast aluminum construction
  • Made in the USA
Your Price: $14.99
MSRP: $34.99
Save $20.00 (57%)
Order in the next 4 hr 4 min to ship today. Details
Many modern professional audio horns and waveguides feature only two and three bolt mounting patterns for compression drivers. The Eminence S2B-A solves the dilemma of using 1", 1-3/8"-18 TPI screw-on horn drivers with those horns and waveguides.
The cast aluminum design provides a stout, solid connection to both the driver and the horn. Bolt holes are drilled for 1/4"-20 bolts using the standard 3" spacing 2-bolt pattern, and M6 bolts using the standard 2-1/4", 120° spacing for the 3-bolt pattern. The 1-3/8"-18 TPI inner threads fit nearly all standard screw-on type compression drivers. Mounting hardware not included. Made in the USA!
BrandEminence Speaker
ModelS2B-A
Part Number290-561
UPC876358001262
Weight0.25
ConstructionAluminum
Entry / Throat Diameter1"
Mounting TypeHorn Adapter
