  • OPEN BOX Eminence Red Coat Red Fang 10" Guitar Speaker 50W 8 Ohm
CLEARANCE OPEN BOX Eminence Red Coat Red Fang 10" Guitar Speaker 50W 8 Ohm
Eminence Speaker
Part #290-838
Eminence Speaker
Part #290-838
Model: Red Coat Red Fang
Eminence Red Coat Red Fang – Red Fang™ 10…vintage British tone with loads of detail, chime and grit and a nicely defined low end.
It all started with the British Invasion, that unmistakable sound that took America by storm from across the Atlantic to right in your face. And now Eminence puts it within easy reach with the Red Coat™ series of guitar amp speakers. Engineered and manufactured in the U.S. with British-inspired cones, making it easy to "Pick Your Sound." Seven-year manufacturer's warranty.
Red Fang™ 10…vintage British tone with loads of detail, chime and grit and a nicely defined low end. Alnico magnet, steel basket, Copper voice coil
Specifications: • Power handling: 50 watts RMS • VCdia: 1.75" • Impedance: 8 ohms • Frequency range: 70-4,500 Hz • SPL: 102 dB • Dimensions: Overall diameter: 10.11", Cutout diameter: 9.13", Depth: 5.2".
Electric guitars, guitar amplification, and the birth of Rock-n-Roll in the 1950's collectively established a new use for loudspeakers. Speaker choices were limited in those days and amplifier manufacturers had to purchase products that were common to other applications. Usually, this meant a low-power speaker, often with an Alnico magnet, and limited cone and coil travel.
Due to the nature of the speaker's construction, the sound of the guitar and amplifier combination was impacted by the speaker design. Amplified guitar was a bit more aggressive duty than most other speaker applications at the time and the speakers were frequently challenged in terms of their mechanical movement and linearity. Guitarist learned how to control this non-linearity and use the resulting tonal characteristics to their advantage. Speaker break-up became cool and was a desired feature by most guitarists. The great guitar tones we know now are a result of those events.
Although there are a multitude of distinctive guitar speaker tones available today, they can be broken down into two main categories. We have Marshall and Celestion to thank for the distinctively "British tones" that we are so familiar with. Fender, Peavey, and SLM (Crate/Ampeg) worked with speaker companies like Eminence, Oxford, CTS, JBL, and Electro-Voice to establish tones that are distinctively "American".
Eminence is proud to present the Patriot™ and Red Coat™ series of guitar speakers. Incorporating both British and American cone technology into speakers that are manufactured in the USA gives us the ability to provide you with virtually any tone you desire. Be it British or American, clean or dirty, big bass or screaming highs, we have a speaker that will allow you to "Pick Your Sound".
To help you select the right Eminence guitar speaker, check out Eminence's Tone Guide.
BrandEminence Speaker
ModelRed Coat Red Fang
Part Number290-838
UPC876358000937
Weight9.8
Nominal Diameter10"
Power Handling (RMS)50 Watts
Magnet MaterialAlNiCo
MONSTER DEAL
OF THE WEEK
$24.98 EACH
SAVE $5
Lepai LP-2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
