  • Eminence CannaBass CB3015N-8 15" Bass Guitar Speaker 8 Ohm
Eminence Speaker
Part #290-5188
Eminence Speaker
Part #290-5188
Model: CB3015N-8
Presenting the CannaBass™ CB3015N-8, a source of great pride for Eminence. Meticulously crafted with the contemporary musician at heart, the CB3015N-8 showcases a fusion of state-of-the-art speaker technology, the remarkable attributes of a hemp dust cap, and an exclusive CBD coating. Designed to elevate your audio experience, this innovation boasts innate organic damping properties, resulting in an enhanced, unadulterated sound.
  • Optimized cone geometry and materials eliminating break-up modes
  • Rugged cast frame for strength and rigidity
  • Strong neo motor for high efficiency and light weight
  • Incredible 1,000 watt program power handling
Your Price: $279.99
MSRP: $341.99
Save $62.00 (18%)
Order in the next 3 hr 20 min to ship today. Details
Introducing the CannaBass™ CB3015N-8, a pinnacle of audio excellence. Its black paper cone is ingeniously fortified with a CBD coating on its rear surface, imbuing it with exceptional damping properties that amplify its seamless frequency response. The conscientious choice of utilizing a green hemp dust cap not only upholds eco-friendly principles but also contributes to the CB3015N-8's natural damping capabilities, culminating in a sound quality of pristine purity.
Designed for musicians who demand nothing short of the best, the CannaBass™ CB3015N-8 boasts a high-temperature Neo magnet. This magnet's remarkable blend of potency and lightweight design, combined with robust durability, results in a magnetic field of unwavering stability that directly translates into superior sound quality.
With an impressive 7.22mm xMax and a music power rating of 1,000 watts (500W EIA), the CB3015N-8 has been meticulously voiced to deliver a resounding, distortion-free low-frequency range. This meticulous engineering lends itself perfectly to the preferences of modern musicians seeking a commanding and high-fidelity sound.
Moreover, the incorporation of a three-inch inside/outside wound voice coil on a vented fiberglass bobbin is a testament to our commitment to accuracy and authenticity. This ingenious configuration significantly reduces power compression and distortion, guaranteeing that the sound remains true, pure, and undiluted. The CannaBass™ CB3015N-8 is more than just a loudspeaker – it's a testament to our dedication to sonic perfection.
BrandEminence Speaker
ModelCB3015N-8
Part Number290-5188
UPC876358007356
Weight10.3
Nominal Diameter15"
Bolt Circle Diameter14.56
Power Handling (RMS)500 Watts
Frequency Response40 to 3,700Hz
Sensitivity98.1dB 2.83V/1m
Voice Coil Diameter3"
Magnet Weight11oz.
Resonant Frequency (Fs)40.67Hz
DC Resistance (Re)5.5Ω
Voice Coil Inductance (Le)0.59mH
Mechanical Q (Qms)3.6
Electromagnetic Q (Qes)0.43
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)5.75ft³
Mechanical Compliance of Suspension (Cms)0.16mm/N
BL Product (BL)17.76T·m
Diaphragm Mass Inc. Airload (Mms)96.75g
Maximum Linear Excursion (Xmax)7.22mm
Surface Area of Cone (Sd)856.3cm²
Surround MaterialCloth
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter15.32"
Baffle Cutout Diameter14.03"
Depth7.1"
Vented Volume2.75ft³
Vented F354Hz
