  • Eminence APT 150S 100x50 1" Horn Flare 1-3/8"-18 TPI
CLEARANCE Eminence APT 150S 100x50 1" Horn Flare 1-3/8"-18 TPI
Eminence Speaker
Part #290-559
Eminence Speaker
Part #290-559
Model: APT 150S
Choose the APT 150S horn flare from Eminence to create a wide dispersion output when used with 1" screw-on compression drivers.
  • 100 by 50 degree dispersion pattern for wide coverage area
  • Designed to work with 1-3/8"-18 TPI compression drivers
  • Durable ABS construction
  • Same horn flare as used on the Eminence APT-150 and Eminator EM:150 Super Tweeters
Eminence's constant directivity APT 150S horn flare is built to work with screw-on 1-3/8" 18-TPI compression horn drivers, creating an 50° vertical and 100° horizontal conical dispersion pattern for focused output. This durable ABS construction wave guide is great for use in two and three-way pro audio speakers.
Specifications: • Nominal dispersion: 100° H x 50° V • Minimum frequency: 1,500 Hz • Throat diameter: 1" • Overall dimensions: 4.49" H x 7.55" W x 3.18" D • Cutout: 3.4" H x 6.7" W • Mounting type: 1-3/8"-18 TPI.
BrandEminence Speaker
ModelAPT 150S
Part Number290-559
UPC876358000920
Weight0.27
ConstructionABS
Entry / Throat Diameter1"
Mounting Type1-3/8"-18 TPI
