Eminence Alpha 3-32 3" Full-Range Speaker 32 Ohm
Eminence Speaker
Part #290-4018
Eminence Speaker
Part #290-4018
Model: Alpha 3-32
The Alpha 3-32 from Eminence Loudspeakers will allow you to pack big performance into small spaces. Perfectly suited for portable speaker systems, column, and line array applications this is a truly versatile full range driver.
- True full range response with useful output up to 20,000 Hz
- 32 ohm impedance is ideal for series-parallel wiring in multiple driver systems
- Unique internal neodymium magnet improves efficiency and high frequency response
- Impressive efficiency for a driver this small
- Poly coated paper cone produces smooth response and resists water
