  • Electro-Voice ETX-35P ETX 15" Three-Way Powered PA Loudspeaker
$1,499.00
Ships in 7-10 Business Days
Free Shipping available on orders over in the US. Details
The new ETX family of powered speakers builds upon the innovation and 85?year heritage of Electro?Voice audio engineering to offer the most advanced professional portable powered loudspeakers available today. The groundbreaking ETX Series is a versatile choice for live entertainment venues, rental companies, pro musicians and DJs, and installed sound.
The ETX family of powered speakers features three two?way models (10", 12" and 15", all with a precision HF titanium compression driver), a three?way model (15" with a 6.5" MF driver and a precision HF titanium compression driver) and two subwoofers (15" and 18" drivers). All models have an easy-to-use single-knob DSP which includes presets for multiple configurations and top+sub combinations. All ETX models are also designed for floor, stacked, or pole mounting (0 or 7.5 degrees) for portable use or permanent installation. The subs feature a dual-duty pole cup which is compatible with both 1-3/8" and M20 threaded poles.
Positioned above the ZLX and Live X families respectively, ETX powered loudspeakers complete a trio of recent EV portable loudspeaker offerings ? each of which was designed to bring best?in?class performance to its price point.
Inside each low?profile, tour?grade wood enclosure are a range of unique new features that set ETX Powered Loudspeakers apart, combining intelligent technology and innovative industrial design for spectacular results across all applications. EV?engineered high?efficiency transducers and high?powered Class D amplifiers, Signal Synchronized Transducers (SST) waveguide design and smart FIR?Drive DSP all work together to provide peerless EV sound quality and precise coverage at the highest SPLs.
Specifications: • Power rating: 2000 watts • Frequency response: 48 - 20,000 Hz (±3 dB); 38 - 20,000 Hz (±10 dB) • Maximum SPL: 136 dB • Coverage pattern: 60° x 40° • Enclosure: 18 mm, 13-ply birch plywood • Connectors: 2 XLR/TRS combo inputs; XLR link output • Suspension: 10 mm fly points x 8 • Power requirement: 100 ~ 240 VAC, 50 - 60 Hz • Dimensions: 40" x 18" x 17" (1032 x 469 x 426 mm) • Weight: 84.2 lbs. (38.2 kg).
