  • Panasonic EAS14PL327A6 6" Paper Cone Woofer 6 ohm
BUYOUT Panasonic EAS14PL327A6 6" Paper Cone Woofer 6 ohm
Factory Buyouts
Part #299-4138
Factory Buyouts
Part #299-4138
Model: EAS14PL327A6
The Panasonic EAS14PL327A6 6" paper cone woofer is ideal as a replacement woofer, or as the low-end in your next budget build.
  • Shielded magnet assembly is suitable for use near sensitive electronics
  • The basket uses high-quality stamped steel for outstanding stability under extreme stress
  • The bumped back plate allows the high-temp voice coil to move even more, so you get deeper bass without distortion
BUYOUT $9.98
MSRP: $19.99
Save $10.01 (50%)
Quantity:Qty: 1-9 $9.98/ea
Quantity:Qty: 10-19 $9.48/ea
Quantity:Qty: 20+$8.98/ea
Order in the next 19 hr 32 min to ship today. Details
264In Stock
Sporting a paper cone and foam surround, the Panasonic EAS14PL327A6 6" woofer is a well-built, smooth sounding woofer that will work equally well in ported or sealed enclosures. A 1" diameter 4-layer copper voice coil handles ample power and a vented cone helps keep things cool under high power applications. A bucking magnet allows close use near older CRT screens or mechanical hard drives without negative effects.
BrandFactory Buyouts
ModelEAS14PL327A6
Part Number299-4138
UPC848864072180
Weight1.7
Nominal Diameter6"
Bolt Circle Diameter5.5
Power Handling (RMS)40 Watts
Power Handling (MAX)80 Watts
Frequency Response50-4,000Hz
Sensitivity85.72dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)53.06Hz
DC Resistance (Re)4.819Ω
Voice Coil Inductance (Le)1.316mH
Mechanical Q (Qms)8.686
Electromagnetic Q (Qes)0.5594
Total Q (Qts)0.5256
Compliance Equivalent Volume (Vas)0.3191ft³
Diaphragm Mass Inc. Airload (Mms)12.77g
Surface Area of Cone (Sd)95.55cm²
Cone MaterialPaper
Surround MaterialFoam
Voice Coil FormerPaper
Overall Outside Diameter6.125"
Baffle Cutout Diameter4.75"
Depth3.25"
# Mounting Holes12
