  • Dynamat Professional Heavy-Duty Rubber Roller with Wood Handle
NEW Dynamat Professional Heavy-Duty Rubber Roller with Wood Handle
Dynamat
Part #260-601
Dynamat
Part #260-601
If you're tired of dealing with finger cramps and torn damping material while installing sound proofing material, we've got the perfect solution for you - Dynamat's professional heavy-duty rubber roller. This innovative tool is designed to make your damping process a breeze while ensuring proper adhesion for professional results.
  • Wooden handle and heavy-duty for durability
  • 2" wide rubber covers more area with each stoke versus smaller ones
  • Smooth rolling action ensures proper adhesive over damping material without causing tears, wrinkles, or other forms of damage
NEW $18.95
Out of Stock
The Best Tool to Use When Installing Damping Material
Say goodbye to those painful finger cramps that often come with manually pressing and smoothing damping material. The Dynamat heavy-duty rubber roller allows for a firm and controlled grip, reducing strain on your fingers and hands. With its ergonomic design, you can comfortably roll and apply pressure to the damping material without experiencing discomfort or fatigue
Not only does this roller provide a comfortable experience, but it also prevents tearing and damage to the damping material. The heavy-duty rubber construction ensures that the roller glides smoothly and evenly over the surface, eliminating the risk of tearing, wrinkling, or other forms of damage. This means you can achieve a professional-quality result without any setbacks or wasted material.
The Dynamat professional heavy-duty rubber roller is the ideal tool for anyone working with damping material, whether it's for soundproofing, vibration control, or heat insulation. Its effectiveness and efficiency make it a must-have for professionals, hobbyists, and DIY enthusiasts alike
So, why put up with finger cramps and damaged damping material when you can make your projects more comfortable and successful? Invest in Dynamat's professional heavy-duty rubber roller and experience the difference it can make. Say goodbye to frustration and hello to smooth, effortless damping application. Get yours today and take your projects to a whole new level!
BrandDynamat
Part Number260-601
UPC769103100078
Weight0.4
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
