Dynamat Dynapad 21100 4-Layer Composite Barrier 32"x54" RollDynaPad stands as a robust, 3/8" thick, one-pound-per-square-foot floor mat, engineered with a four-layer composite barrier employing "Dissimilar Layer Insulating" technology. It effectively tackles two challenging automotive issues: exhaust system heat and low-frequency noise. Featuring a heavy-duty vinyl barrier sandwiched between two layers of acoustic "sound soaker" foam, DynaPad is encased in an oil and water-resistant poly facing.
Primarily utilized beneath the vehicle's carpet, DynaPad serves as the ultimate upgrade for carpet padding. Its application is especially beneficial in scenarios demanding exceptional noise and heat control, such as in large diesel trucks with pronounced engine and exhaust noise. The sturdy composite barrier of DynaPad effectively neutralizes low-frequency exhaust and road noise while providing heat insulation.
DynaPad installation is hassle-free as an under-carpet pad, requiring no adhesive and allowing for repositioning and reuse. It can be applied on floors, interior firewall, rear deck, and in the trunk to ensure a serene and comfortable environment. For optimal results, DynaPad is recommended to be installed over Dynamat Xtreme, offering a comprehensive solution and delivering the renowned Dynamat Difference.
