Denon DP450USBWT HiFi Belt Driven Turntable WhiteElevate the precision of your vinyl collection at home or seamlessly convert cherished vinyl tracks into MP3 or WAV file formats with the USB output for on-the-go enjoyment. The DP-450USB, equipped with a pre-mounted MM cartridge, built-in phono preamp, and a meticulously engineered tonearm featuring auto lift and playback stop, ensures the playback of your entire vinyl collection in pristine quality. From vintage gems to the latest releases, experience the trusted Denon sound quality in every note.
The integrated USB-A output enables convenient one-touch recording of your favorite vinyl records directly onto a USB drive in MP3 or WAV format files. Whether playing your albums on the DP-450USB or recording them for on-the-go enjoyment, experience the renowned Denon sound quality wherever you choose to listen.
Unboxing and operating the DP-450USB is a breeze, taking just minutes for both novice and seasoned vinyl enthusiasts. Simply plug it into your preferred amplifier or system, and you can instantly rekindle your connection with your vinyl collection—it's that straightforward.
Capable of playback at 33 1/3 rpm, 45 rpm, and 78 rpm, the DP-450USB allows you to effortlessly enjoy your entire vinyl collection, including cherished vintage 78s, in their full breadth.
The modern design of the removable dust cover enhances the overall aesthetic of the DP-450USB, simultaneously addressing vibration issues that can impact music quality when covers are attached. Additionally, the dust cover doubles as a display stand for your album cover. Simply place it upright on the included base, allowing you to showcase your album proudly to friends and family.
Features
- DC Belt drive motor
- S-Type tonearm
- Manual operation
- Speeds: 33-⅓ & 45 RPM
- Wow & flutter: 0.10% WRMS
- Built-in switchable photo EQ
- Stylus version DSN-85
- Rated output: 2.5 mV/1kHz
- Frequency Range: 20 Hz - 20 kHz
- S/N Ratio: 62 dB
- Maximum dimensions: 16.2" W x 13.7" D x 5.7" H
- Weight: 12.4 lbs
