  • Denon DN-200BR Bluetooth Audio Receiver
Denon Professional
Part #245-3670
Denon Professional
Part #245-3670
Model: DN-200BR
The DN-200BR from Denon Pro incorporates consumer audio devices into professional sound systems via Bluetooth, for wireless convenience with the excellent sound quality and reliability you expect from Denon.
  • Adds Bluetooth to virtually any audio system
  • Balanced XLR and unbalanced 1/4" audio outputs
  • Up to 82 ft. (25 m) range
  • Discreet, robust build quality that can mount nearly anywhere
Your Price: $129.00
Order in the next 2 hr 56 min to ship today. Details
With countless Bluetooth-enabled audio sources roaming the planet, the DN-200BR interfaces them all with a professional audio system for sound reinforcement, special event or retail applications. It receives Bluetooth signals wirelessly, then routes the audio to balanced XLR or 1/4" outputs for integration with mixers and amplification systems. Its Bluetooth Pairing mode ensures a secure connection.
Denon Professional's Solution Series is designed to be the best friend of audio contractors. The ultimate goal is solving audio challenges easily and inexpensively by getting signal to someplace that would be otherwise difficult or inconvenient. Simple to install, configure and operate, the Solution Series products belong in the toolbox of every audio installer.
Specifications: • Frequency response: 20-20,000 Hz (+1 dBu) • Bluetooth version: 2.1 + Enhanced Data Rate (EDR) • Maximum receiver power: Class 2, 4 dBm • Receiver frequency: 2.4 GHz - 2.48 GHz • Receiver range: up to 82 ft. (25 m) • Receiver sensitivity: -80 dBm @ 0.1% BER • Supported codec: SBC, MP3, AAC, aptX • Supported profiles: AVCTP 1.0, AVRCP 1.0, GAVDP 1.2, AVDTP 1.0, A2DP 1.2, Hands-Free Profile (HFP) 1.5, Headset Profile (HSP) 1.1 • Output level: +4 dBu (balanced); -2 dBu (unbalanced) • SN ratio: > 75 dB • THD: < 0.01% • Supply voltage: 100~240 VAC, 50/60 Hz • Power adapter: 5 VDC, 3A • Dimensions: 5.8" x 4.6" x 1.8" (149 x 117 x 45 mm). • The provided antenna is a magnetic mouse type and the cable length is 6 feet (2 m)
BrandDenon Professional
ModelDN-200BR
Part Number245-3670
UPC694318017777
Weight2.1
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
